Samsonite Silhouette 11 Hardside Spinner Logo
Posted on Jun 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cannot open my luggage. It seems to me the combination system is locked inside and its impossible to open the luggage.the three combination numbers can be moved from 1 to 0 but it dooes not open.what can I do please?
  • Anonymous Mar 14, 2014
    Forget combination Luggage lock on Atlantic luggage
  • Anonymous Mar 22, 2014
    Combination lock
Anonymous
Level 3:
Genius:
  • Master 1,970 Answers
  • Posted on Jun 28, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1970
Questions
0
Helped
847443
Points
4702
Mcdevito75 here, You can try to see any place that sells luggagde in your area for help.
2answers
How to open a jammed suitcase latch with known combination?
Just reset the combination:
  1. Set the dial to 000.
  2. Turn the shackle at a 90 degree angle from the lock position.
  3. Push the shackle down (outside of the lock).
  4. Set the desired code.
  5. Pull the shackle up.
  6. Turn it back to the lock position.
https://thetravelshots.com/travel-tips/
2answers
I have forgotten the digital number of my luggage lock -Eminent brand. How to unlock it ?
Yoong queen,
You can able to open this number lock, but you show more patience,
put the lock number to 000 or 0000, then start with 001,002,,,upto 999 or 9999 if it is fourth digit. Each time you every digit give a slight pressure to the lever,,it will open with the correct number and open with that number you forget.
with regards
jaijith
2answers
How to change the 3 digit code of my samsonite ?
Luggage manufacturer Samsonite offers a variety of business, personal, travel products and accessories. Many Samsonite pieces such as attaches and other bags include a three-digit, built-in combination lock. When purchased, the locks are set on a factory default combination that you can change as often as you wish.
STEP 1
Turn the number dials to the previously set combination, or to "0-0-0", the factory default combination for Samsonite luggage.
STEP 2
Locate the reset button, usually placed to the side of the combination dials.
STEP 3
Press the reset button and hold it while rotating the number dials to the desired combination. Set this to a sequence easy for you to remember but hard for others to figure out.
STEP 4
Release the reset button after you set the numbers to the new combination.
STEP 5
Test the combination by turning the dials to the new code to open the lock. If the combination does not open the lock, repeat Steps 1 through 4 and test the lock again. If you still can't open the lock, contact Samsonite Customer Service at 800-765-2247.
How do I can unlock dial lock
The master dial lock is the world's best selling combination padlock.The lock uses three digit combination of 40 numbers.allowing for 15,00 possible variations
.Follow these step to unlock dial lock. 25284217-gdc3ufgmlwaqnv2deqjxyac2-5-0.jpg With the Combination Step 1 Turn the lock until the numbers read right-side-up. Roll the left-most dial until the first number of your combination lines up with the scored hash mark just to the left of the dial.
With the Combination Step 2 Roll the middle dial until the appropriate number lines up with the number to its left. Do the same for the right-most number. Your three-digit combination should now show, left to right, lined up with the scored hash marks.
With the Combination Step 3 Pull the body of the lock away from the U-shaped metal ring without turning any of the dials. The lock will click open to expose a hook. The hook spins 360 degrees so that it can be placed onto, and taken off, luggage.
Forgotten Combination Step 1 Pull the body of the lock and the U-shaped ring away from each other to put pressure on the mechanism inside the lock. Pull the body of the lock away from its attachment, or, if the lock is not attached, apply pressure on the U-shaped ring away from the body of the lock with your fingers. Keep holding a firm, steady pressure.
Forgotten Combination Step 2 Roll the dial closest to the U-shaped ring slowly, while keeping steady pressure on the mechanism. The dial will get difficult to roll over three consecutive numbers, and one of those numbers will click. You should feel and hear this small click, and that is the first number to your combination.
Forgotten Combination Step 3 Repeat Step 2 with the middle dial, and then the farthest dial. Leave the dial set when you find the click, moving onto the next dial. The combination will reveal itself, letting you pull the U-ring away from the body of the lock.
Resetting Your Combination Step 1 Hold the body of the lock so that the numbers face away from you. Set the combination and release the U-shaped ring.
Resetting Your Combination Step 2 Turn the hook of the U-shaped ring counterclockwise 90 degrees until the notch on the stem of the hook and the hole on the body of the lock line up. Push the stem of the hook down into the body of the lock as far as it will go.
Resetting Your Combination Step 3 Turn the hook another 90 degrees counterclockwise while it is depressed into the body of the lock.
Resetting Your Combination Step 4 Roll the dials until you have your new combination.
Resetting Your Combination Step 5 Turn the hook 90 degrees clockwise and raise the stem out of the body of the lock. Turn it another 90 degrees clockwise and push it back into the locked position. The lock now uses your new combination.
Sponsored Links
Luggage Trolleys Supplier
Supplies Made to Order from World's Largest Supplier Base. Top Deals!
www.alibaba.com $0.01 Web Hosting
Scalable, Secure Web Hosting. Try Our Award-Winning Service Now!
www.hostgator.com/1Penny Rooftop Air Conditioner
low noise, high static pressure. Made in China, Inquire Now!
www.airconditionings.cn Download Facebook Apps
Get The Most Popular Apps For The Largest Social Network. Join Now!
www.facebook.com by Taboola
Sponsored Links
Move Over, Turkey: 9 Side Dishes that Will Steal the ShowKraft Recipes See Another Side of Dubai in HattaDepartment of Dubai Tourism & Commerce Marketing by AFAR
Email Best Practices: Sending Emails That Won't Be IgnoredRackspace
TIP
  • Email yourself the password to your lock, and title the email "Luggage Lock." If you forget the password in the future, simply search your email for the term "Luggage Lock."
WARNING
  • Do not open a lock that does not belong to you. It is against the law.
REFERENCES
RESOURCES
ABOUT THE AUTHOR Christopher Michael began writing in 2004 for his college newspaper. He received a Bachelor of Arts in English and psychology, as well as a certificate in criminal justice from the University of Massachusetts, Amherst.
PHOTO CREDITS
  • Creatas/Creatas/Getty images
Suggest an Article Correction
How to Open a Combination Lock on a Samsonite Suitcase
  • How to Reset the Combination on an American Tourister
  • Airline Rules on Locked Luggage
  • How to Reset a TSA Lock
  • Reagan Airport & Luggage Storage
  • How to Prevent Lost Luggage
  • Cost of Shipping Luggage Ahead to Destination
  • How to Repair Wheels on Luggage
  • The Odds of Losing Luggage
  • How to Make Inexpensive Luggage Tags
  • Solutions to Lost Luggage in Air Travel
  • How to Measure Luggage
  • How to Expedite Lost Luggage Claims
  • What Are the Dimensions of Hand Luggage for Air France?
  • What Rights Do I Have If My Luggage Is Lost?
  • How to Store Luggage While Traveling in Italy
  • pixel.gifHappy Camper: Test Your Outdoors Knowledge
  • pixel.gifCruisin' Along the PCH: Test Your Knowledge
  • pixel.gifWhich U.S. Landmark Would You Be?
  • pixel.gifCan You Pass for a Proper Brit?
  • 0helpful
    Eminent luggage lock
    TSA lock on Eminent Osmosis Luggage, three digit TSA lock (HOW to change it to YOUR personal number)
    Put the code numbers to '000'
    Take the lock levers OFF the lock
    Push the round opening button UPWARDS.
    IMPORTANT :
    KEEP holding the button UP until you have changed the numbers
    Change the TSA code numbers to what YOU want
    Release the round opening button
    Now your case combo lock numbers have been changed.
    To lock the case put the two lock levers into the holes, spin the numbers and your case will be locked.
    To UNLOCK the TSA code spin the numbers to YOUR lock code, push the lock button UP and, hey presto, your case will open.
    If you forget your NEW lock number you will NEED to go through ALL the numbers, starting at '000' to '999', to be able to open the lock/case.
    REMEMBER to PUSH the ROUND OPENING button UPWARDS on EVERY number change.
    Only THEN, when it finds YOUR correct three digit number, will it eventually open the suitcase/luggage/baggage.
    Good luck
    4helpful
    I HAVE FORGOTEN THE CODE COMBINATION OF vip LUGAGE TROLLEY BAG SO PLEASE HELP
    Please check out this page: http://www.vipbags.com/support/luggage-care-faqs
    VIP provides assistance if you forgot your combination code. If this is not an option, first try all the combination, 000, 001 etc. Birth dates, last/first three digits of your phone number, car number etc. If this is not an option either, take it to the luggage seller, they can break the lock. If everything else fails, then you need to cut it open.
    Oct 29, 2012 • Cell Phones
    2answers
    I previously set my combination and it worked fine. Now my combination will not work on my cal pak lock luggage. how can I open now and reset combination?
    Try rotating the numbers on the combination dial three times to clear any previous entry (stop on the zero's if this applies) and enter your combination one more time to see if this works and gets it open.
    The default is 000; to set it, hold the lock open, move the dials to your numbers, and close/open three times. This will set the combination to your numbers.
    11helpful
    2answers
    Set luggage lock
    the lock is currently set to 000. To set your own combination and with the lock in the 000 position, open the case and on the inside of the lock mechanism you will see a red tab. slide this tab to the left and then move the digits on the front to your desired code. ie 123. then move the red tab back to lock in this new setting as your own personal combination. close the case and then move the digits away from our setting of 123 and this locks the case. only if the digitrs are 123 in this example will the lock now open.
    Top Samsonite Luggage & Travel Experts
    ADMIN Andrew
    ADMIN Andrew
    Don A
    Don A
    Are you a Samsonite Luggage and Travel Expert? Answer questions, earn points and help others
