I started using DVD-RW mini disks on my DC173(U) camcorder on my Alaska cruise last week (after having used DVD-R disks in the past). After recording about 15 minutes of short video clips (out of the 20 minutes disk capacity) during my trip, the disk "became" (showed up as) "unformatted" when I turned the camcorder on. The screen then provided options to format the disk (as VR or Video format). Of course I didn't format it, as I believe I would loose all my video clips. My repeated attempts to restart (boot) the camcorder with the disk did not result in the recovery of this disk error.
Is there a way to recover (from that disk error) or extract the (video clips) data from the disk ? i.e. like a way to get the camcorder to initiate a "recovering data" routine (which I've seen before) .... or any suggested tool/utility/software that I can use to read (& save) the video data from the disk (sectors) ... ? (containing DVD output data from this camcorder)
I subsequently started on a new DVD-RW disk, and it happened to the 2nd DVD-RW disk as well after about 12 minutes of recording.
The Samsung technical support rep (that provided on-line chat assistance) was unable to offer any help; i.e. he told me the video data is lost, and to use another pack (brand) of mini DVD disks to see if it happens again.
Thanks !
SOURCE: "No Disk!" Error
hi there, have you refered to the manual which type of dvd your cam reads?
you usually get this "no disk" on screen when inserting a non readable disk or a disk that it doesnt support.
hope this helps
SOURCE: No Disc Message
from what i read it looks like you should be using
miniDV Tapes
Model #: JVC MDV60DU5whats the model number of the maxell you have?
SOURCE: write error
I think i just figured it out. Somewhere else on the web clued me in that the disc got messed up (don't know how). I put in a new disc and it works. Other disc still doesn't though.
SOURCE: samsung SC-DC173(U)
I've been trying to find out the same information. We went to disney this year lost 3 full dvd's worth. Called samsung all they told me was to use memorex mini-dvd's. Thanks alot ):
Anyways hopes this helps a little.
I've (finally) been able to recover all (if not most) of the contents - video clips from the (bad/corrupted) miniDVD-RW ... and even from my previous miniDVD-R disks ... (that I had recorded using the Samsung videocamera). I use the software tool - IsoBuster Pro . The process (to recover) may be long ... i.e. it may take several to many hours for one miniDVD disk ... but it worked for me.
I've (finally) been able to recover all (if not most) of the contents - video clips from the (bad/corrupted) miniDVD-RW ... and even from my previous miniDVD-R disks ... (that I had recorded using the Samsung camcorder). I use the software tool - IsoBuster Pro . Inserted the mini-DVD into the DVD drive on my PC/laptop, and started the software . The process (to recover) may be very long .. i.e. it may take several to many hours for one miniDVD disk ... but it eventually enable me to retrieve the (lost) video clips.
