Question about Broderbund Printmaster Silver 12.0
I have cracked my program disk for printmaster platinum 12 where can I get a free download of the program disk
    Scholar:
  • 94 Answers
You are gonna love this site. It is called www.emule.com you can down load anything, I mean anything for free, and your print master cd you should be able to get right away, see the way the site works is it grabs bits and pieces from owners arouond the world, so if you are looking for some high price software, you leave it running in the back grouund for as long as it takes, a day? 3 days? a couple hours, now this little old cd you need, you should be able to get it right away, also here is another idea, if the cd is cracked, but not cracked in half all the way, super glue it, but use very little as possible then clean cd to make sure there is no glue exposed on the cd surface, and it will work, let me know how this goes.
Posted on Jun 28, 2010
SOURCE:
How can I run PrintMaster 16 Platnum in Windows 7
Printmaster 16 Platinum is an older program and is compatible with XP and older versions of Windows.
First check which version of Windows 7 that you have. Click Start > Control Panel > System and Security > System. If your version title ends with x64, you will need to use an option that lets you run an older version of Windows. If you do not see x64 in the title, then the compatibility mode might work.
For the 32-bit OS, right click on the installer and choose Properties. In the Compatibility tab, check the box for always run in the compatibility mode and select an older version of Windows. Apply the changes and click OK. Then right click again and choose Run as Administrator. You may need to repeat this to run the software as well. This is not guaranteed to work in Windows 7 32-bit.
The alternative is to run an older version of Windows. This could be on a second computer, a dual boot computer or a virtual computer (if your hardware supports the feature). Most of these methods require licensed version of the older Windows OS. If you have Windows 7 Pro or Ultimate or upgrade to them, you can run a virtual XP OS for free. Download Virtual PC and XP mode from Microsoft. Then install the Printmaster program in XP as if this is the only OS. (Other virtual computer programs are Parallels and VMWare.)
The only other option is to upgrade to a version of Printmaster that is Win7 compatible. One option is Printmaster 2012 Platinum available here: http://www.broderbund.com/p-273-printmaster-2012-platinum.aspx .
I hope this helps.
Dec 10, 2011 | Broderbund PrintMaster Platinum 16
My wife has been using Printmaster for years and has created thousands of projects. Her latest version is 18. We got a new computer with Windows 7 and it said that version 18 is not compatible. So we...
Installing PrintMaster 18 on any computer requires .NET Framework 1.1 to be installed on the hard drive. If NET Framework 1.1 is not installed, it will be installed from thePrintMaster 18 install disk before PrintMaster 18 is installed. If possible download .NET framework 1.1 If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant" in Windows 7 will display this message.To continue with the installation, select "Run Program".
Feb 18, 2011 | Broderbund PrintMaster Platinum Version 18
Get "Error 1305" when I try to reinstall my
Error 1305 means that the computer is not reading the disk. Most likely you have a dirty, or scratched disk. It could be that another program or process is keeping the disc
1. First make sure that the old program is completely uninstalled.
2. Restart your computer. Keep all other programs closed.
3. Clean the disc with a lint free cloth.
4. If this doesn't work, wash the disk with warm water, and allow to dry thoroughly, another suggestion would be to purchase a CD cleaning kit.
5. See if the disc works in another computer or drive. The problem could be your CD-ROM drive. Older drives cannot read dirty or scratched discs as well.
If the above steps do not work, it is likely you will have to replace the disc.
Oct 30, 2010 | Broderbund PrintMaster Platinum 16
Is there a manual with the Printmaster 17?
you can download the manual from my website
http://tricia8765.fatcow.com/COMPUTERTRAINING%20MANUALS.htm
you will see it is around the fourth entry on the link
Jan 17, 2010 | Broderbund PrintMaster® Platinum 17 Full...
I purchased a printmaster platinum 12 in 2002 and loved it but now i am trying to download the software into a diffrent computer since out other computer crashed. i have my registration # but i can only...
I am guessing that your new computer has windows vista on it. That may be the reason Printmaster 12 will not install. Certain programs or their installations are not compatible with Vista.
I'm not sure what errors you are getting, and I am assuming you are running Windows Vista, so again I'm just guessing.
You could try to launch the setup program manually and using compatibility mode by following these steps:
1. Insert your installation disk.
2. Click the start button
3. Click on Computer
4. Right click on the drive containing your installation CD
5. Select Explore from the menu.
6. Find the Setup or Install file in the list.
7 Right click on it.
8. Select Properties.
9 Select the Compatibility tab at the top.
10. check "Run this program in compatibility mode for"
11. In the drop down menu select windows xp
12. check "disable visual themes"
13. Check "run this program as administrator" (if it is available)
14 click OK
15 now double click on the setup/install program.
I hope this solves your problem.
Thanks!
Nov 03, 2009 | Broderbund Printmaster Silver 12.0
PRINT MASTER PLATINUM 12 INSTALL DISK
yes, only because i'm totally awesome. ^_^
go here:
http://www.demonoid.com/files/?category=0&subcategory=All&quality=All&seeded=0&external=2&query=+PRINT+MASTER+PLATINUM+12&uid=0&sort=
Now this is version 16. but should do all you want. if you are not a member of demonoid.com it is free to do so. if registrations are closed use this invitation code to join :
HempKnight420Xdkh8uoyqgb1prclmijy9wubr8wfgfxk
Sep 10, 2009 | Broderbund Printmaster Silver 12.0
How to configure Printmaster 12
melodie roba,
Most definitely this could be your problem! I would reccomend that you completely uninstall Printmaster 12, run another virus check, then reinstall the program. Once the program is installed, update it through the vendor and it should work fine. You should be able to find the vendor (PrintMaster) updates through the help menus.
Hope this helps,
-samson39
Jul 26, 2009 | Broderbund PrintMaster Platinum Version 18
My printmaster Platinum 10 version will not install on Vista.
downgrade too XP 10 is not compatible with Vista
May 02, 2009 | Computers & Internet
How do I uninstall printmaster silver 12
the question was regarding PrintMaster Silver 12, although it was posted in the PrintMaster Platinum 16 forum.
Anyway, Broderbund has the instructions on their web site
http://support.broderbund.com/fix.asp?isid=30284&print=0&prog=1294819732
Oct 18, 2008 | Broderbund PrintMaster Platinum 16
Broderbund Printmaster Silver 12.0 Logo
360 people viewed this question
Top Broderbund Computers & Internet Experts
Peter Dragonetti
Norman Worley
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
