Cars & Trucks Logo
Posted on Jun 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I took my fuel pump off my 06 Ford F350 diesel because it would not start. The fuel pump hums but will not pump diesel out of a bucket. Is this normal, or is it bad?
Anonymous
Level 3:
  • Master 383 Answers
  • Posted on Jun 28, 2010
Anonymous
Master
Level 3:
Answers
383
Questions
0
Helped
135439
Points
1196
Well u tell me is a fuel pump job to pump or hum?
yes if it only hums it bad
2answers
I have a 2003 ford f350 fule pump has ben replaced but still not getting no fule
Is this a diesel or gas vehicle ? and what engine does it have ? They all have different type of systems . Diesels have a low pressure and high pressure pump and IPC and IPR valves . Gas vehicles have different controls ,( FPDM ) fuel pump driver module that is controlled by the engine computer ,with the help of a fuel rail pressure sensor. There is problem with the FPDM because of it's location under the vehicle . How To Fix the P1233 FPDM No Start Condition DTC Ford Truck Technical... 06 Ford Powerstroke diesel no start low injection pressure icp ipr
1985 ford f350 diesel will not allow the ignition to engage. Dash light says water in fuel. I put on a new fuel filter. Did not help. Can I bypass the sensor?
The Diesel engine doesn't have an ignition system. Also the dash light shouldn't cause it not to start? You said you changed the fuel filter right? After you started cranking it again did the lift pump fill the new filter up. I have had these before where the lift pumps go bad causing low lift pump pressure which causes the water in fuel light to be on. Did it die going down the road or did you shut it off and can't get it restarted.
14helpful
3answers
I ahev a 2005 ford f350 with 6.0 diesel, i am
Bad Injectors most likely. I have a 2006 f-350 and was having the same problem. I ended up changing the fuel pump and 4 injectors.
29helpful
3answers
Ford f350 diesel truck 30 amp fuse keeps blowing.
1helpful
2003 ford f 350 diesel cannot get the engine to
CHECK ELECTRIC FUEL PUMP FUSE THAT SUPPLYS THE INJECTION PUMP FUEL.IF ALL IS GOOD.REPLACE FUEL FILTER AND AIR FILTER.MAKE SURE GLOW PLUGS AND GLOW PLUGS CONTROLLER IS WORKING. IF NOT. THAT WILL CAUSE NO STARTING PROBLEMS BIG TIME.
2helpful
2004 Ford F350 diesel, changed fuel filters hard starting
Pull the filters and ck for plastic or o-ring in wrong place. Something is up in the filter.
1994 F350 WILL NOT START
you simply have to bleed the fuel lines...
to do that just loose up the line and have someone rotate the engine until you have some fuel going there...
make sure that your fuel filter is full because you will do this for nothing...
it should only take like 5 minutes of bleeding...
F350 no start
I have a feeling you got a wholed of unleaded fuel or bad fuel
I drive a diesel box truck the station I always took it to the fuelman put unleaded in the diesal tanks and the truck just died it had to have the gas tank completed drained and cleaned out but also ask yourself how many miles are on it and when was last tune up and if you live in a cold climate I recommend a heater block plug
2answers
2002 f350 wont start
i had to replace my oil pressure regulator sensor it contols the oil pressure required to have the injectors open and spit fuel, if you replaced it and still no start replace the the cam position sensor
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
