The mixture should be at a 50:1 ratio, using Premium Exact Mix™ 2-cycle engine oil. If Premium Exact Mix™ 2-cycle engine oil is not available, use a high quality 2-cycle engine oil, mixed at a 50:1 ratio.
You can get the manual on the link below if you need it also.
https://www.dixiesales.com/ipl/338/ut08120b%20manual_254_eng.pdf
Good Luck and please rate 4 thumbs up for the free answer.
