Maytag Jetclean® III MDB9750B 24 in Builtin Dishwasher Logo
A
Anonymous Posted on Jun 27, 2010
Maytag Jetclean® iii MDB9750B 24 in Builtin Dishwasher is leaking from the bottom. Looks like seal between pump and washer body is busted. Can i re-seal it with cocking or something?
Anonymous
Level 3:
  • Maytag Master 43,501 Answers
  • Posted on Sep 29, 2010
Anonymous
Maytag Master
Level 3:
Answers
43501
Questions
0
Helped
10843724
Points
101584
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
lkldfgjgsad
The spongee seal at the bottom of the dishwasher door is leaking. How can I fix it?
Leaking Dishwasher
heatman101
retodfkjhgofd
1helpful
My maytag jet clean dishwasher is leaking
I hope this helps. If this is your model... here is the replacement part. Or you will be able to find your seal here by putting in the correct part number or model number.
CLICK HERE
If you can replace the seal yourself you will save a lot of money!
Good Luck!
My Maytag washer leaks at the door. It doesn't
f you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is sudsing too much. Cut back on the amount of detergent you use, and see if that makes a difference.
Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment.
Also make sure the dishwasher is sitting level (you can adjust the front feet up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repairperson.
An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Rate the solution..
I have residue on dishes with a maytag mdb7600
clean out the food trap in the bottom inside of the dishwasher.  Also your water may not be hot enough...either select hot wash or increase your hot water heater temp.
Brand new dishwasher installed and water leaks out bottom of door
If your dishwasher leaks, check these:
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal Note…If the main motor of your dishwasher is mounted vertically, beneath thecenter bottom of the dishwasher, the following instructions probablyapply to you. But if your motor is mounted horizontally, the pump isn'tserviceable--you need to replace the entire pump and motor assembly.
Themain tub seal is beneath the drain impeller. It prevents the water inthe dishwasher from leaking out near the shaft of the motor. To get tothe seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal Overtime, door gaskets and seals harden and lose their ability to sealproperly. You can't repair the seals. You need to replace them ifthey've begun to leak.
Water-inlet valve Thewater-inlet valve, itself, seldom leaks. But, the water-supply linefrom the house and the rubber tube leading from the valve to the insideof the dishwasher may leak. Tighten or repair/replace these asnecessary.
The water-inlet valve could mechanically stick open.When that happens, the water continues to flow into the dishwasher,which then floods your kitchen. Turn off the water supply to thedishwasher, and replace the valve.
Hoses Behindthe lower access panel on your dishwasher are several rubber or plastichoses. If the leak appears at a connection, try a new clamp. If thatdoesn't work, replace the hose.
1helpful
Maytag dishwasher heavy door (broken door spring(s))?
Hi thanks for the question. to repair . bottom kick plate must be removed ,to get to the door springs .4 screws . remove them. springs on each side . replace them thanks the appliance doc.
Top Maytag Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
