Polaroid FLM-3232 Television Logo
Posted on Jun 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a red flashing light inside right hand of rear of tv the sound or the color screen doeesn't work
Bud Martin
Level 3:
  • Master 11,361 Answers
  • Posted on Jun 27, 2010
Bud Martin
Master
Level 3:
Answers
11361
Questions
Helped
3368865
Points
33650
Tv will not turn on, red flashing light comes then turns off
tv will not turn on, red flashing light comes then turns off.
light flashes six times.
Tv turns off red light flashes and i hear a chriping sound
This problems is also parts of tv convergence board have dead 2 STK convergence ICS and some or all the resistors dead too.This problems the 2 STK and some or all it resistors are completely dead that why u only have red flashing light and chirping sound only.If your tv have any life function left of the tv convergence board u would have only mis alignments of colors R,G,B lines,have colors shadows or 3D pictures look alike.The shop,will cost like $300-350 to get the tv convergence board fixed also fixed this problems too.
The tv has power .the red light is on ,but when it turns on,the green light comes on but then it turns right back off ant the light goes back to red it has a round 1/2" button like plastic plug in...
Tod,
The little plastic button you are referring to is the IR receiver for the Remote. When the TV turns itself off, are there any flashing lights on the front or rear of the unit. Look through the vents in the rear for any flashing lights or try tuning the tv on in a dark room and see if any lights flash and reflect off of walls. If there are flashing lights tell me how many flashes and what color and I will try to look them up in the manual.
Picture has become darker and darker, but now there is no picture or sound a red flashing red light in the lower right hand corner.
Time to replace lamp in tv.
Existing lamp in tv is dead and tv needs new lamp to work again.
Lamp replacement procedure is easy and written in user manual of tv.
Sony KP-41T65 41" rear projection tv with convergence issues on part of the screen. And screen is generally slightly blurry. I received this TV already broken (had the red blinking light issue) which I...
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
2answers
Continuous flashing red light
This set should go in for repair new sets can have alot of different problems color wheel could be bad.
2answers
Tv black, no sound
is there any led or small lights on front panel ... red green or flashing
Philips 9P6040C 60 in. Rear projection
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Here are some of the most common symptoms.
  • Screen looks 3D
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site http://www.TvRepairKits.com . They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Hope this helps,
2answers
Red screen on LG 44-inch DLP
Go to this site, follow the instructions, and it might fix your problems. I did, and my tv is better than ever!
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Picture & Color Distorted
Convergance IC replace.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Top Polaroid Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
