Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on Jun 27, 2010
Error code F 35 and SUD code
When i've gotten the F 35 code before the load was partially wet and some clothes completely dry, so i just repostioned them and started over but i keep getting this message now more frequently
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jun 27, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
876
Points
7
Save yourself a lot of time and money and replace the analog pressure switch. This will solve your issues by taking care of both error codes at the same time.
The Appliance Pro
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 29, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
743
Points
0
F35 and sud code. washer stops shortly after cycle begins.
Kenmore 110.66902690 electric dryer does not dry completely
Dear Barry,
Try 2 things.
One, be certain the clothes are very dry coming out of the washing machine.
If the washer leaves the clothes wet ( like the belt might be slipping), it can take the dryer forever to finish drying the clothes.
You can tell by hand-wringing them.
You should not be able to get any water out of them by hand-wringing after they have spun dry in the washer.
Two, try running a load with the vent hose unhooked off the back of the dryer.
If this fixes the problem, you are having a "clogged vent" issue somehow.
Be blessed.
Apr 16, 2013 • Dryers
Have a year old Whirlpool Ultimate Care II. After wash is spun and load is done the clothes are still sopping wet. Tried extra rinse but that doesn't help. Afraid of damaging dryer when putting clothes...
Check to make sure a nail has not gotten stuck in one of the hole in thew bottom of the drum. Check to see that no article of clothing has gotten jammed between the tubs or the top.
An error code keep coming up. sud reads on the display instead of time, and clothes are not done still wet
The part is call analog pressure sensor switch . And you are using the wrong soap for the machine
2answers
My kenmore washer showes sud code
If it is similar to the Whirlpool duet,
Try using less soap (hi eff machine)
try using more fabric softner
to clear the occasional Sud warning, I run the machine on "quick wash" with no detergent/additive. gives it two more quick spin cycles in 30-35 minutes, usually clears it.
5helpful
WHAT IS ERROR CODE 35 OR ERROR CODE 37? ON MY FRONT LOADER.WFW9600TA00
does it say f35 and sud?
you need a new pressure switch
sounds like a new washer is it 1-2 years old?
2helpful
2answers
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Close are Too Wet
Are you getting any type of error message on the display?
How long have you had the washer? Have you ever cleaned out the filter?
I also have a Duet (2 years old) and my clothes were not spinning out as well as they once did. I started getting a SUD error message with almost every load and then started getting a F5 message which the manual says it means it's not draining correctly. It never said how to fix it though. Went into the panel underneath washer, found the clean out plug for the drain...it was gross! Cleaned it out, washer works like new again.
Maytag neptune front load
sounds like possible blocked internal filter or partial pump blockage
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
