J AI UN IMPREMANTE CANON 2900APRES L INSTALATION ELLE S AFFICHE UN CODE E1000000 J AI FAIT BEAUCOUP D ESSAY POUR ARRIVER A RESODRE SE PROBLEME MAIS J AI PAS ARRIVE JE DEMANDE AIDE ET MERCE BEAUCOUP
I also had a similar problem. I Fix it up ,Just follow following Steps
1. Open the cover of the printer.
2.Take the cartage(Where the ink id refilled ) out from printer.
3.There is a Drum like Structure in the cartage..(The problem is with the Drum ,i man that the drum is stuck so it does not rotate while printing(ie Error code is generated).
4.Now gentally try to rotate the drum (but you should not use vey small force to rotate as the force might not be able to rotate stucked drum).
5.If it rotate ,do it for some time (1 or 2 complete rotation)
6.Fix the cartage in the printer.
7.Close the Cover..
ITs all.(This works for me ,Wish it also Work for You!).
[email protected]...
Unplug the power cable and change the USB Port and uninstall the printer then install the printer again. And remove the caritage (toner), restart your computer then install the cartiage again........ It will definately work......
SOURCE: i have an error code on my printer Error Code: E100 0000 .
uninstall the printer and install the new software of the printer and it will run rate me please
