If you still can't remove stuck paper, it's REALLY stuck. Take it to a repair service. apart of removing all that paper, they should diagnose WHY you got a mega-stuck.
Forced removal might damage your printer
If its some thing that just started, then you may want tocheck if you are using a new paper manufacturer. Sometimes frequent jams arecaused by thin paper.
One of the more common problems with printers as it relates to paper jams, is that the paper stacked in the tray hasn't been fanned. What I mean is, it's like holding a paper-back book in your hand and skimming quickly through the pages with your thumb as your other hand holds it at the spine. Try this as a remedy if your printer jams often.
Does it feed sometimes, and just jams frequently, or every single page? Are you sure the paper size in the tray is set correctly? Otherwise for frequent or constant jams when the paper simply stays in the tray, then the feed rollers are likely worn out.
Having too much paper in the paper tray will cause your printer to have more frequent paper jams and double printing. Make sure you fill the paper to the fill line. I usually recommend going a little below line. I would also recommend that there is no paper from your previous jams still stuck in there. That will cause it to jam up as well.
Heavy
cardstock and certain types of slick or coated paper can cause frequent
paper jams. To better isolate the cause of your problem (machine or
paper), try a new ream of regular 20 lb copy or laser paper.
Don't Overload Overloading your paper tray can cause
paper jams. Your manual may say that your input tray can hold 250
sheets -- but if you keep getting jams, try loading 225 sheets instead.
Check the Paper Check the minimum/maximum paper weights that your printer can handle. Paper that is too thick, or too thin, can cause jams.
If you still get paper jams after this may be its time to clear the internal of the machine..You might want to have a look at the following link..
