I am having a problem with gta iv on my mother's computer wich is a windows 7 built by emachines. I need a processor just like the following: AMD Athlon X2 64 2.4Ghz. The problem with gta 4 is that it's only doing 9 or less frames per second. Can you help me with this dilemma???
When Processors (CPU) are made, they are made on a Pass/Fail scale. Processor is either Good, or not good.
This means you may get a Processor that is on the Top of the scale, or Bottom of the scale. The AMD factory doesn't discriminate.
In fact they don't care. (This goes for all Processor manufacturers, not just AMD) All they care about is does the Processor work, or not?
Therefore, you may have a Processor that is on the Bottom of the scale, but passed as Good.
Point? Stating a setting that might be good for joeblow's AMD Athlon 2650e, may not work for yours.
Might work for yours, and not joeblow's.
This is why you need to go into BIOS Setup, and using a SMALL increment, overclock the Processor. Run the computer for 24 hours, and see if everything is chiily. (Computer still works OK) This is a "Burn-In test"
Works OK for 24 hours? Then go back into BIOS Setup, and go up one more small increment. Do the Burn-In test.
Keep going until the computer has glitches, or doesn't work. Then go back into BIOS Setup, and come down one small increment, or go back to where the computer WAS working OK.
It's an individual thing. Each Processor (CPU) is different from the others.
For additional questions please post in a Comment. Regards, joecoolvette
Hi It would with better if you will use joystick controller to enjoy playing GTA , Its just like your playing game console by using joystick controller. You check the price of joystick controller for your computer online or nearest computer center
-The specification of your computer meets the system requirements and I believe that your not going to have any problem installing GTA also playing GTA. Minimum System Requirements:
800 MHz Intel Pentium III or 800 MHz AMD Athlon or 1.2GHz Intel Celeron or 1.2 GHz AMD Duron processor 128 MB of RAM 8 speed CD / DVD drive 915 MB of free hard disk space (+ 635 MB if video card does NOT support DirectX Texture Compression) 32 MB video card with DirectX 9.0 compatible drivers ("GeForce" or better) Sound Card with DirectX 9.0 compatible drivers Keyboard & Mouse
Recommended System Requirements
Intel Pentium IV or AMD Athlon XP processor 256(+) MB of RAM 16 speed CD / DVD drive 1.55 GB of free hard disk space (+ 635 MB if video card does NOT support DirectX Texture Compression) 64(+) MB video card with DirectX 9.0 compatible drivers ("GeForce 3" / "Radeon 8500" or better with DirectX Texture Compression support) DirectX 9.0 compatible sound card with surround sound Gamepad (USB or Joystick Port) Keyboard & Mouse
first of all, you didn't mention what GTA you are playing,. but if my guess is right I think that's the GTA IV or something similar to that one,. well you see those graphics of this game is so intense especially the effect and its wide range of map,. I recomend you to upgrade your machine your processor use an AMD with fusion technologyor better and if your fun of intel use also there latest like i3 or i7,. second is your RAM if your running XP 2048 g is the minimum of the game requirement, but then if you are using win 7 or Vista, you should add up more, up to at list 3060 g of RAM or higher,.... last is your VGA or graphics card, you should also consider its size and performance install a 1024 g size of VGA,. will I guess that's it,
Microsoft® Windows® 7 Enterprise, Ultimate, Professional, or Home Premium (compare Windows 7 versions); Microsoft® Windows Vista® Enterprise, Business, Ultimate, or Home Premium (SP2 or later) (compare Windows Vista versions); or Microsoft® Windows® XP Professional or Home edition (SP3 or later)
For Windows Vista or Windows 7: Intel® Pentium® 4 or AMD Athlon® dual-core processor, 3.0 GHz or higher with SSE2 technology; for Windows XP: Intel Pentium 4 or AMD Athlon dual-core processor, 1.6 GHz or higher with SSE2 technology
Running GTA 4 on windows 7 should not be a problem. You just have to run the installer using compatibility mode. Right click on the "setup.exe" then choose Properties. Go to Compatibility tab and tick "run this program in compatibility mode for", choose windows xp sp 3. That should allow you to install GTA 4 on windows 7. Bear in mind that you have to install GfW Live and the C++ 2005 files seperately which can be found in the disk as well. More importantly, make sure that your computer meets the system requirements for the game.
Here it is: System Requirements
OS: Windows Vista - Service Pack 1 / XP - Service Pack 3
Processor: Intel Core 2 Duo 1.8Ghz, AMD Athlon X2 64 2.4Ghz
Memory: 1.5GB, 16GB Free Hard Drive Space
Video Card: 256MB NVIDIA 7900 / 256MB ATI X1900
Processor: Intel Core 2 Quad 2.4Ghz, AMD Phenom X3 2.1Ghz
Memory: 2 GB (Windows XP) 2.5 GB (Windows Vista)
18 GB Free Hard Drive Space
Video Card: 512MB NVIDIA 8600 / 512MB ATI 3870
After installing the game and you're not able to run it, Try running the main executable file of the game in compatibility mode as well.
