There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
SOURCE: Dehumidifier runs but does not extract water
Found out about the filter on the left side of the unit. Mine was caked with dirt and would not allow air to pass. Cleaned with nozzle from vacuum and it works great now.
SOURCE: comfort-aire Dehumidifier bhd-651
Most likely the fan motor is broke. I have seen several units with bad fan motors.
SOURCE: Delonghi DE220 dehumidifier stopped extracting water from the air
You probably have a dirty heat exchanger. Write to me at [email protected] for free maintenance instructions on a smilar unit. Cheers.
SOURCE: Dehumidifier only two years old now doesn't
Problem is that you bought a dehumidifier made by the Korean/Chinese manufacturer LG.
Search the web and you will find that you are just one of many whose dehumidifier worked the first year but now draws no water out of the air even though it makes all the right fan and compressor noises.
Most common problem is that all the Freon refrigerant escaped, apparently because the copper tubing cracked and leaked. Penguins beware, there goes the Ozone Hole!
It cost me $14 and an afternoon of investigation and testing of my LG 504EL dehumidifier to figure this out. The fix-it web site "Just Answers" said that it wasn't worth fixing after I described all the symptoms. Tomorrow I will go to the local LG fix-it shop and try to get a replacement to tide me over until I can find a reliable dehumidifier.
Sadly, last Fall I took my 25 year old Westinghouse (made in America) dehumidifier to the dump. Even though it needed me to tune it up every year or two, at least I could fix it and it kept on working for 25 years.
enterich
