Question about Dishwashers
A small plastic food container top melted and hardened to the ring in my dishwasher. How do I remove it please?
    New Friend:
  • 122 Answers
You can try putting dishwasher in dry cycle and let it heat up enough to soften the plastic so you can pull it off. otherwise a new element.
Posted on Jun 27, 2010
Testimonial: "Thanks, it worked. The dishwasher stills has that burning smell,but wil fade away eventully."
SOURCE:
I have a new bag of granulated sugar. It is rock hard. How do I soften it?
hi Diane.
  1. Place the sugar into a heavy-duty plastic food storage bag. ...
  2. Use the flat side of a meat tenderizing hammer or a rolling pin and pound the bag until the pieces are broken into chunks.
  3. Place the chunks of sugar into the bowl of a food processor. ...
  4. Pour the sugar into an airtight container.
  5. How do you make white sugar soft again?
    Here is an easy way to make hardened granulated sugar soft again -- Preheat oven to lowest temperature, 150-200 degrees. Remove sugar from the package andput in an ovenproof container that will hold the sugar. Place in the warm oven for approximately 15 minutes. Tap sugar with a spoon.
Dec 01, 2017 | Garden
How do I remove melted plastic from top stove burner, kitchen aid oven/stove, branch new
Clean the stove so all food residue is removed. Take a single blade razor blade and very slowly scrape the edges of the melted plastic. Blade should be held at a low angle, and only a small amount should be cut away at a time. It will take time, but the plastic will come off.
Once clean, use the manufacturer approved cleaner to clearn the area.
You may want to try to turn the burner on for about 10 seconds on high, and then off to help soften the plastic. Be careful to not burn yourself.
Mar 08, 2015 | Kitchen Ranges
Like so many others, I am experiencing a problem with my GE dishwasher's smartdispense. I have ALWAYS used the SAME detergent(Cascade Complete)and still have the gumming-up issue. I noticed that the...
I had the same problem as you also using Cascade Complete. It turned to a wet solid and completely cloged up. I have spent 3 days cleaning it and now have it working again. I had to spoon out what I could, but the purge method still would not wash through. I started putting in water, running a thick plastic coated wire in and moving it around. Then opened and closed the door to slosh thinks around, then took a small scoop to clear out the water and gel clumps. I kept repeating until tired. Added more water and let it set over night and started again the next day. Once the water started looking clear after soaking and digging with the wire. I ran the purge technique listed in an earlier post, and the blockage finally cleared. It now is working again. I plan to keep a close eye in the future and run the purge as a regular maintence on ocassion when the add detergent light comes on. (I wonder if Cascade changed the formula that caused this gelling, or if they have a product issue).
Aug 17, 2010 | Dishwashers
Water won't go to the top spinners
there is probably food stuck in the spinner,
ive had to remove the spinners on my mind one a year, and use the pressure washer on them, to get out the small chucks of food, and or plastic pieces.
Yes i know we can rinse more, but hey no one is perfect :)
Aug 21, 2009 | Kenmore Dishwashers
Water will not drain. Motor is working. Drain does not appear to be clogged.
GE has equipped many of their dishwashers with a crappy anti-syphon ball. The problem with this is that they often relocate and clog the drain. To fix it, syphon all the water out of the basin of the diswasher and remove the kick plate. Open the dishwasher and remove the 1/4" hex head screw behind the food screen and remove the spray arm by prying the plastic clip on the back side (be careful not to break it). Then remove the two 1/4" hex head screws in the plastic basket and remove it. Remove the two screws that hold the dishwasher to the countertop and slide the dishwasher out. There is a large manilla colored hose with a huge hose clamp on it. Have plenty of rags on hand because this part gets messy. Remove the hose clamp and pull this area open. A small white plastic ball should roll out. Replace the hose clamp and slide the dishwasher back into place (clean up all the water that escaped first, and make sure you have turned off the power to the dishwasher before beginning). Drop the ball into the small tube on the left side under where the plastic basket goes. Installation is reverse of removal.
Aug 03, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
My whirlpool dishwasher doesnt not drain completely empty
check grease trap[ located after l/panel is removed,it is a plastic container] have power disconnected first. if too much hardened grease is there thats your problem.where i live,only whirlpool contractors are allowed to repair same.come back to me if this is the problem.regards
Jul 26, 2009 | Dishwashers
Intake/drain light is flashing
When this happens with my dishwasher it usually means that the drain is clogged with food/debris.  To fix 1) remove bottom dish rack from machine 2) using a small cup, scoop out as much water as possible 3) remove inlet drain cover and unsnap the plastic insert and remove 4) rinse the plastic part and reinstall 5) start machine 6) if light still flashes, repeat steps 3 4 and 5 and restart
Jul 18, 2009 | Miele G892SC SS Dishwasher
Kenmore 665 15899 dishwasher won't clean
Make sure the filter inside the dishwasher is cleaned out and read about my advice for dishwashers for more tips.
<a href="http://tclaundryrepair.com/">St Paul Appliance Repair</a>
Jan 31, 2009 | Kenmore 15899 Built-in Dishwasher
Dishwasher safe?
I would not reccomend it. The water, soap etc is safe, but the heat drying process risks melting parts, and they are surprisingly expensive to replace for being plastic.
-Tha Mp3 Doctor
Sep 18, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
A child's plastic cup top melted on heating element. . .how to remove residue
Gently scrape with a razor blade or paint scraper to remove the large pieces, then use some emery paper or very fine sand paper to remove the rest. Use care when applying any pressure on the element, and try not to leave any gouges in the element surface. I have also had good luck with a nail file. Hope this helps you.
Feb 01, 2008 | GE 24 in. Profile PDW7800 Built-in...
Dishwashers Logo
143 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
