Flash setting is stuck on "flash off" and wont change
Whenever i try to change my flash setting to either "auto flash", "flash on", or "red eye reduction" it wont change. it stays in the flash off setting.
Hu,
Just set your digicam to always flash whenever take photo rather than auto or red eye reduction modes. It will keep your flash when take photo.
If it is not work, then your camera has problem on board and need repair at dealer or local shop.
Regards
Press Right on the cursor button (marked with the lightning bolt icon) to switch the flash setting. Your choices are AUTO, AUTO/Red-eye reduction, Forced ON, Forced ON/Red-eye reduction, Slow sync/Red-eye reduction, and Forced OFF.
hi, even i have the same problem, probably i don't think the flash doesn't work, but even i didn't know how to use it. however, the instruction manual says there are 3 options in flash, they are auto- that is it turns flash automatically on when it turns on.
red eye reduction that is it says it will flash twice to reduce red eye but i never see the flash on and the flash off, that is it will not turn on and usually whenever you exit the camera the flash will default to turn off mode. you will need to switch the flash back. hope you understand.
Check the flash mode that your camera is set to. The flash modes are: Auto, Red-Eye Reduction, Forced Flash, No Flash, Slow Synchro, and Red-Eye plus Slow Synchro. You might have the flash mode set such that your camera detects that the lighting doesn't require the flash mode selected. You can try manually overriding the flash mode by pressing left on the circle function button next to the LCD view screen. If you are still unable to manually turn the flash on, try changing the shooting mode with the mode select dial on top of the camera, then if necessary repeat the flash override step mentioned above. Repeat until successful. There is also the possibility that the flash is malfunctioning, but that is less likely than a setting issue. Let me know how you make out.
The red is the reflection of your flash on the retinas of your subjects. The white are generally animal eyes reflecting back.
You will notice this on flash shots only and mostly when you use the zoom. The zoom uses a "narrow" field of view so the light that reflects back is "direct", instrad of at an angle.
The fix: Change the ISO setting (it is set too high). It is probably near the maximum sensitivity (3200?)... set it to 400 or so and try that for a while. 800 is probably the best general setting, but try 400 first.
Try not to use the flash unless you really have to, but only if the subject is less than 12 feet away. If no people are in the picture, you may use the flash for subjects greater than 12 feet.
RED EYE is caused by the sudden flash from your camera and the eyes reflex reaction to the sudden light. So what the red eye reduction does is to double flash to counter the reaction. You can try adding an external light source to to your subject. in addition to the following procedures for your camera in the manual, the indicator location on page 64 Flash On Flash Off Red-eye reduction C REC modes on page 52, Snapshot; pg 64, have the flash fire automatically when required (Auto Flash) * Turn off the flash ... recording with flash, reducing the chance of red-eye in the image (Red- eye reduction) In this case, the flash fires automatically;
Also, be aware of the following:
The approximate effective range of the flash is shown below. Wide Angle Optical Zoom: Approximately 0.4 to 2.9 meters (1.3´ to 9.5´) (ISO Sensitivity: Auto) Telephoto Optical Zoom: Approximately 0.4 to 1.6 meters (1.3´ to 5.2´) (ISO Sensitivity: Auto) * Depends on zoom factor
in the "best shot" mode i have it set to auto.
