I have a Nutone central vac model CD353 and the unit does not shut off, I have disconnected the yellow wiring for the outlets it still runs and then the switch on the unit and it still runs so I am thinking that the relay is not shutting off the unit. So I am trying to see if I could buy the relay because it looks easy to change (just disconnecting and connecting the wires). Does that sound like the problem or could it be something else I should test. So looking for some advice
You probably have a stuck relay. You can try tapping with medium force next to where the low voltage wires are attached to the unit using the handle end of a hammer. Even if this works it's time to replace the circuit board. Take the unit to a local vacuum repair center for service.
