1/28/13 - I have Janome Harmony 2049 that was initially sewing forward with no reverse and then after about 12 inches of sewing would ONLY sew in reverse. After spending an hour getting the plastic housing off...I was able to locate the shaft that made the reverse. It needed lubrication and after working it in and unjamming the part from the down position, the forward and reverse now work! Huh, right? Hope it continues to work well. It is a smooth running machine, otherwise. Good luck!
Sounds like the machine's age is causing the lubrication to get sticky.
Try changing the pattern by moving the pattern selector around.
Take out the bobbin and remove the thread and presser foot, raise the presser lever, set the pattern to zig zag, set the stitch length to maximum and run the machine at full speed. While it's running, repeatedly press the reverse lever all the way down. Run it for at least a few minutes.
Be sure you are in the correct stitch pattern...if you are on a buttonhole stitch or a stretch stitch it normal for the machine to sew backwards. Be sure your length is to the right of 0 and not in a strtch stitch model or buttonhole mode.
