SOURCE: My brand new Moen faucet gives almost no hot
If you soldered the valve together with the cartridge still inside you may have over heated the plastic and warped something. The balancing spool sounds like it is stuck.
SOURCE: We have a home that
Remove handle to gain acess to the temperature limit stop. Remove handle and pull out handle adapter kit and next there is a dail that can be adjusted to control the water to balance the temp. It could have been installed wrong, pay attention to where it is now and pull it back to it disengages out of the stem and move it counter clockwise a little and reinstall. Put handle on and test water for correct movement.
Go to link below for a part's diagram if needed.
TO ORDER PARTS CALL: 1-800-465-6130
www.moen.com
SOURCE: can you adjust hot to cold ratio on moen single
Pull off the handle and there are limiters located under it. They come set with not enough hot allowed, I have found. It is an anti scalding issue.
