Hi:
There a two capacitors that needs replacing in the power supply. the value of these caps are 1000uf rated for 10vdc, replace them with 1000uf rated at 16vdc.
Having browsed the user manual I wonder if you plugged in the Sony BDV T57 Home Theatre System while the Polaroid FLM-2632 tv was powered down via the optical cable .
Then powered up the Sony BDV T57 Home Theatre System first and then powered up the Polaroid FLM-2632 tv
Maybe the Polaroid FLM-2632 TV has to detect that the Sony BDV T57 Home Theatre System is connected and powered up when the Polaroid FLM-2632 powers up. To activate its digital audio out ????
The note part about only being available only under HDTV (cable/air) mode. Might be the cause of your hassle also ?
DIRECTLY FROM THE USER MANUAL
source from http://tv.manualsonline.com/manuals/mfg/polaroid/polaroid_flm_flm2632.html
" ? Connecting to Audio Receiver:
Use an audio cable to connect the audio receiver's audio LINE IN jacks to LCD TV's
AUDIO OUT jacks. ? Connecting to Digital 5.1 Sound System:
METHOD A:
Use an optical cable to connect the audio amplifier's OPTICAL IN jacks to LCD TV's
OPTICAL OUT jacks.
METHOD B:
Use a coaxial cable to connect the audio amplifier's COAXIAL IN jacks to LCD TV's
COAXIAL OUT jacks. Note: Above mentioned function is only available under HDTV (cable/air) mode.
? Connect all AC power sources, before turning on the power switch of the LCD TV or
other connected equipment.
? Press the button on the remote to turn on the LCD TV."
Have you misplaced your Polaroid FLM-373B LCD HDTV Service Manual?
Would you like a digital, searchable, pdf version of the Polaroid FLM-373BLCD HDTV Service Manual? Follow this link (& click FREE) to download a pdf version of the operations manual.
Have you misplaced your Polaroid FLM-373B LCD HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Polaroid FLM-373B LCD HDTV Users Guide? Follow this link (& click FREE) to download a pdf version of the operations manual.
Try to narrow down the bad section of the audio signal chain by hooking up powered PC speakers to the audio line out to see if you do get the sound there, if you do then the problem can be in the power amplfier section, if you do not get the sound at line out then it can be in the sound processing circuits, here is the service manual: http://www.polaroidsupport.com/polaroid/docs/FLM-Series-26-32-37_ServiceManual_20070418.pdf
Have you misplaced your Polaroid FLM-3732 LCD HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Polaroid FLM-3732 LCD HDTV Users Guide? Follow this link (& click FREE) to download a pdf version of the operations manual.
Have you misplaced your Polaroid FLM-323B LCD HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Polaroid FLM-323B LCD HDTV Users Guide? Follow this link (& click FREE) to download a pdf version of the operations manual.
This problem is often replated to a leaking power supply capacitor on the secondary side of psu rated at +/- 2000uf at 12v...yup 4 bucks should do it...the hardest part is often opening the power supply up screws are often located underneath rubber feet....never make contact with the primary ac supply side even after it is unplugged reservoir capacitor high voltage can store a charge for long time and be dangerous to contact.
Have you misplaced your Polaroid FLM-3232 LCD HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Polaroid FLM-3232 LCD HDTV Users Guide? Follow this link (& click FREE) to download a pdf version of the operations manual.
Have you misplaced your Polaroid FLM-2632 LCD HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Polaroid FLM-2632 LCD HDTV Users Guide? Follow this link (& click FREE) to download a pdf version of the operations manual.
