Kenmore 95822 / 95824 / 95829 Electric Kitchen Range Logo
A
Anonymous Posted on Jun 26, 2010
I get a code f90 when trying to either lock the oven door or attempting to clean the oven
Anonymous
Level 3:
  • Master 15,935 Answers
  • Posted on Oct 01, 2010
Anonymous
Master
Level 3:
Answers
15935
Questions
19
Helped
5036853
Points
35540
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question####
2 Related Answers
Anonymous
  • 8197 Answers
  • Posted on Dec 16, 2008
SOURCE: oven door locks and un locks code F90
The F90 fault indicates that the maximum time allowed for oven door unlock was exceeded. The control attempted to unlock the door. The door lock motor or mechanism failed to unlock the door within the maximum amount of time it is allowed to be energized by the control board.
It is unlikely that you will be able to reset this fault code. You can try to completely disconnect electrical power and leave it off for 5 minutes. After reconnecting power, the fault code will probably reappear since the control will still detect that the oven door is locked. The only way to clear the fault code is to disassemble the range and repair or reset the oven door lock assembly. You will need a service technician to complete this repair.
Anonymous
  • 15935 Answers
SOURCE: self-cleaning error message f90
unplug the range.
wait 1 minute.
wait 2 minutes.
2helpful
Oven has f90 error code and door stays locked cannot get oven top door
unplug the range.
wait 1 minute.
wait 2 minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@@@@
I'm trying to clean my self cleaning I am getting an F91 code? Can you help
unplug the range.
wait 1 minute.
wait 2 minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$%$%$%
Code f90 indicated
unplug the range.
wait 1 minute.
wait 2 minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#$%#
3helpful
My frigidaire gas range has a F90 on it when I tried the self cleaning oven feature
unplug the range.
wait 1 minute.
wait 2 minutes.
F90 code on Fridgidaire range/oven
unplug the range.
wait 1 minute.
wait 2 minutes.
1helpful
F90 code flashing and i cant reset it
unplug the range.
wait 1 minute.
wait 2 minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
Beeps - won't stop - f90 code - thinks door is locked.
unplug the range.
wait 1 minute.
wait 2 minutes.
2helpful
Self-cleaning error message f90
unplug the range.
wait 1 minute.
wait 2 minutes.
F93 fault code
unplug the range.
wait 1 minute.
wait 2 minutes.
3helpful
Self Cleaning
unplug the range.
wait 1 minute.
wait 2 minutes.
Top Kenmore Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
