Hussmann Commercial Freezer DCCG-12 Logo
Posted on Apr 15, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hussman DCCG Freezer
I have changed the light bulbs and they will not work properly now. How can I fix the proublem?
Anonymous
Level 2:
Scholar:
  • Expert 149 Answers
  • Posted on Apr 23, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
149
Questions
0
Helped
69167
Points
258
Are they the florescent tube type?? i suspect that the ballast went bad
Light on outside of stand up freezer not work. This light shows the freezer has power how do you fix. Light on outside of the door on freezer no access from the inside
If the light on the outside of the stand-up freezer is not working, first check the light bulb to see if it needs to be replaced. If the bulb is not the issue, then check the wiring connections to ensure they are properly connected. If the connections are loose, tighten them to see if that resolves the issue. If these steps do not work, it may be necessary to replace the light socket or contact a professional to assess and repair the issue.
Apr 16, 2018 • Freezers
Skandiluxe freezer seals
Hi
Most freezer lights are screw on bulbs. Unscrew the bulb unticlockwise and replace with a new one.
Feb 15, 2014 • Freezers
Freezer light won't come back on .
Is that a florescent bulb in the freezer? Or is there some kind of light bulb in the freezer? If so, change the bulb. I'm not being funny. You give no information on what make, brand and year of the freezer to give you any help.
Apr 07, 2013 • Freezers
I replaced compressor for a hussman refrig and its hums loud
God day,
Some thoughts.
1. Are the evap fan motors running, and at full speed. That would give you abnormally low suction pressure.
2. Cap tube sized too small. or partial restriction in the dryer cap tube/dryer when brazing in the lines.
3. Low ambient. What's the temp the machine is running in.
4. Over sized compressor.
5. Moisture. God, 134A is touchy on that one.
6. Was original cap tube soldered to the suction line to create a heat exchanger. Needed on many apps. Definately would cause flash back on start up.
7. Superheat a little low, should be 12 to 15 degrees.
1helpful
Defrost circut wired hot nuetral ,should this be d/c with a transformer
Probably uses a Paragon 8145 timer. Wiring as follows
L1 to 1/2 on timer, L2 to 2 on timer, Defrost Heater to 3 on timer,
Compressor to 4 on timer, Klixon to X on timer
Tripping Breaker
I have the same proublem with mine. It doesn't do it all the time but it does happen..
Top Hussmann Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Hussmann Freezer Expert? Answer questions, earn points and help others
