Pinnacle Studio MovieBox DV 9 (210100349) Video Capture Logo
Posted on Jun 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a MovieBox DV (1394)driver compatible with
I need a MovieBox DV (1394) driver compatible with Vista. I don't want to go thru the whole Studio uninstall-reinstall drill. The Moviebox device is permanently "in use" and has been assigned to some Microsoft driver and shows up as an AV/C device in device manager.
Anonymous
Level 3:
Brigadier General:
  • Master 4,044 Answers
  • Posted on Jun 25, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
4044
Questions
0
Helped
1244382
Points
12252
Pinnacle Software has a Vista Patch to use with their applications that you have to download and install. I had this same problem when I used Pinnacle for my remote camera system.
1helpful
I need power adapter volt/amp
Looks like maybe 3.3 volts, 1.5 amps not sure of the polarity.
The Pinnacle Studio MovieBox DV Includes
  • MovieBox DV external analog to DV converter
  • Full version of Pinnacle Studio 9
  • Hollywood FX transitions
  • TitleDeko for titling
  • 4pin/6pin IEEE-1394 FireWire cable
    6pin/6pin IEEE-1394 FireWire cable
  • Power Cord
  • Power supply: 110V 60HZ 3.3V/1.5A
  • Studio Software 9 manual
  • MovieBox DV hardware manual
3helpful
Does moviebox usb work with studio 14 and vista? I can't get my camera to show as an import device when connected to the movie box.
This is the latest hardware device that can used for Studio 14.
Check the list.
USB based
  • 710-USB
  • 510-USB
  • 700-USB
  • 500-USB
  • MovieBox Deluxe
  • DVC-103
  • DVC-107
  • DVC-100
  • DVC-90
  • DVC-130 (There are no 64-bit drivers for this product.)
  • DVC-170 (There are no 64-bit drivers for this product.)
PCI based
  • 700-PCI (a.k.a. Pinnacle Studio Deluxe 2)
  • 500-PCI (a.k.a. Pinnacle AV/DV)
  • Any 1394 cards.
Are you using vista 32 or 64 bit system? If Vista 64 bit there is no driver for your device and the only available is 32 bit only. Aside from that you can check also the video cable you were trying to used. If firewire under import/capture tab of Studio 14 you need to select the name of your camcorder or dv camcorder. Check that out and try.
Does moviebox usb work with studio 14 on vista?
i want driver for pinnacle movie box deluxe usb on windows seven7 thanks
Unable to get dv input / output via ieee 1394 port
try an older version of pinnacle studio or another pc if still no capture, firewire camera board failed.
3answers
AC power Cord for Pinnacle MovieBox 9
here's some data you may find useful..
1) Manuals are generally available as PDF (Acrobat) on the software CD or DVD
For instance, manuals for Studio 10 are available on the Content DVD (Disk3)
2) You can download the most popular manuals from our public FTP site:
ftp://ftp.pinnaclesys.de/Manual/
Select your product and then browse to select your language.
We are regularly updating the content of this folder.
1helpful
4answers
Saving Dv tape to computer? Getting computer to see camera?
The USB connection is for getting still images (photos) off the camcorder. To get moving images (video) off the camcorder, you must use a FireWire cable (IEEE 1394). The cable only costs about $15. But you need to have a FireWire port on your computer to plug it into -- if you don't have one, you'll have to install a FireWire card. Check someplace like TigerDirect computer parts supplier, they are only $15 to $60 now.
Or, if you don't want to open up your computer to install a FireWire card, you can buy a Pinnacle MovieBox for $120. It just sits next to your computer, not inside. It is very easy to use and comes with great video editing software. You plug the FireWire from your camcorder into the front of the MovieBox, then plug the back of the MovieBox into your computer with USB.
Plus, you can use the MovieBox to record from your VCR or DVD player into your computer! For that, you'll need the standard red/white/yellow cables.
In fact, if your camcorder has those cables, you can use them to go thru the MovieBox, and save yourself the cost of the FireWire cable. But I think FireWire will give better quality than the red/white/yellow cable.
Top Pinnacle Televison & Video Experts
ExpressFiX
ExpressFiX
Vinho Xie
Vinho Xie
Are you a Pinnacle Televison and Video Expert? Answer questions, earn points and help others
