Rolex Explorer II 16570 Wrist Watch Logo
Posted on Apr 15, 2008
ROLEX QUICK-SET FEATURE
How do I use the 'quick-set' feature of a rolex watch to change the date without having to move the hands?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 12, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1212
Points
5
1) un-screw the pin by turning it towards you, until the spring pops it out. 2) pull the pin out to the next notch 3) turn the pin towards you and watch the date change (if the minute hand is moving when you turn the pin, you pulled out too far).
-Mike
www.perfect-timing.biz
Watch keeps running but cant move hands to set time on rolex datejust
Debbie is the watch definitely genuine?
It is a common fault on fake Datejust's..is the crown completely out?
How do u set the date on a datejust
on 1570 movements there is no quickset feature therefore you must turn the hour hand 24 hours to change the date but 3035 and other later movements equipped with quickset wheel and if you pull out the winding crown you can change the date.
I have a vintage Rolex with the serial # 2534788.Would like info on this watch.The face is black with the second hand located where the 6 should be. The name Rolex is written in white under the # 12.The...
This is a tough question. Rolex has always been very secretive of manufacturing information so there is no definitive list of "born on dates" The serial number 2534788 is most likely from 1969 or 1970. The problem is that I know of no Rolex from that time period that has the small seconds hand. The off-set seconds hand was a feature of pre WW2 watches. The case number on the inside of the case back would help in identifying the movement and being able to provide more information
May 22, 2010 • Watches
3helpful
It just wont wind
Wind it back and forth at least 15 times, then twist the watch very quickly back and forth a few times. That should restart the balance wheel moving. Twisting motion must be around the axis on which watch hands are fitted.
I have an old Rolex Geneve Cellini watch gold 12 jewls.. how can i say if its original, not fake.. jan norway
The quickest way to spot a fake Rolex is by the second hand. Is the second hand ticking or sweeping. If it's ticking it's fake. A real Rolex's second hand moves around the dial in one continuous movement.
Check for a small engraved crown on the crystal at 6 o'clock. Most fakes will have something similar. The difference is that the crown on a real one is almost impossible to see by just your eye.
Look for the word "Rolex" and the watch's serial number engraved at 6 o'clock under the crystal on the area between the crystal and the dial. While many fake Rolex watches post-2005 have this feature, they're usually printed, not engraved.
Most other ways relate to newer Rolex watches.
Hope this helps and hope it's the real deal.
7helpful
Rolex watch yacht master set time
Let me start by saying that I own this watch and LOVE it!
To set the time you need to pull the crown all the way out to the furthest position.
To set the date you need to have the crown in the position in between the "winding" position and the "time set" position. Basically, pull the crown out till you hear/feel 1 click to wind, 2 clicks (total) to set the date, and 3 (total) clicks to set the time. I always set the date first to 1 day behind the current date. I then move the crown out to set the time so that I can set the watch to either AM/PM depending on the actual time. For example, I set my Rolex today (the 5th of January at 3pm - just an example). I would first move the crown to the date setting function and move it to January 4. I would then move it out one more position to set the time. I would go around the watch until the date changed to the 5th and then go around from 12 to 12 to change from AM to PM. I would then move it to the 3 and then I'm all set. This is helpful because it will ensure that your date will correctly change when the day changes and not be 12 hours behind.
Jan 03, 2009 • Watches
54helpful
2answers
Rolex oyster perpetual datejust time/date setting instructions
Depending on how old the watch is, It may be quick set or older models are not quick set. In older models you need to unscrew the crown, pull out the crown and rotate the crown to set the time, and in order to set the date rotate the hour hand past 12 twice in order for the date to change. Set the date first and then set the hour and min. For quick set models unscrew the crown and pull it out to the fist click this position you can "quickly" set the date by rotating the crown. Set the date and then pull out the crown to the second position out. Rotate the crown to set the hour and min. Then push the crown back in and screw it down.
2helpful
3answers
Setting the day and date
i am scared of putting to much force turning the crown
It is very hard or stiff ND CAN'T LIFT CROWN TO BR ABLE TO SET DATE AND TIME
4answers
Setting the time
There are two positions for the setting crown all the way out is to set time,one click out to set date.To set the date you must first set the time by moving the hands around clockwise until you see the date change(midnight) then continue around to the correct time.Then push crown in on click and set the date
1helpful
3answers
Setting time and date crown positions
Yes, you must unscrew the crown before you wind up or set the watch. Always screw the crown down afterwards this keeps the watch in a water resistant condition.
Top Rolex Watches Experts
NOEL
NOEL
john h
k24674
Are you a Rolex Watch Expert? Answer questions, earn points and help others
