Have a run out of ink orange light on the printer, printer stops printing. Fitted new tanks to all stations but the orange light is still on and when pressed it goes to each tank in turn telling me to replace it. Is there a sequence to fit new tanks and reset the machines ink empty routine
Many thanks
Raymons.
SOURCE: epson stylus 777 printer
isent this the same printer that you asked about with a problem with the carrage not working correctly after disassembly to rerplace a roller?? If it is then you ptobably have a sensor misalighned or unit still is not "timed" correctly.
SOURCE: ink light on
you must verify all lefvels of yopur ink cartrages some of the others maybe low
SOURCE: New ink cartridge fitted. But still shows empty.
I had the same problem i bought an epson zapper to reset the chips on each cartridge it takes a bit of doing you have to hold each one and do it manualy as the slots on the zapper dont line up but everythig works since and that was a 9months ago since then i have bought a cis unit best thing i ever did no messing with cartridges hope that helps
SOURCE: Printer will not print ,paper comes out blank
Put new in cartridges in printer.
Page prints out blank.
Have cleaned the print heads 3 times.
Need help!
SOURCE: Canon ip 3500 7 flashes of orange
try unplugging it for a little bit and plugging it back in and see if this works.let me know if not then we will try something different.thank you for using fixya.
