Hi Anataloi,
This is due to a hardware failure, the scanner assembly and the formatter board will need to be replaced.
Try doing a hard or reset or nvram:
1. Turn the printer off
2. Hold down the right arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
if this does not work contact hp 1800-334-5144 , if within 2 years from the purchase date ask for a case number to have the printer serviced under a service note.
Al
[email protected]
ON MY HP LASERJET M2727NF SHOWING SCANNER ERROR 5
when i change the mottor on top the scanner it stop the error but the photocopy is fading one corner which is still ok
HP m2727nf scanner error 5
SOURCE: How can I fix error 5 from HP, M2727NF printer?
Unfortunatly I have seen many HP units with Scanner Error 5 . This is usualy caused by a problem in the formatter (mainboard) or scanner assembly. There is nothing you can do to recover it. If the printer is still under warranty you will need to call HP ( 1 800 334 51 44) or take the printer to an athorized warranty depot in your area. This link will help.
http://h20465.www2.hp.com/GPL/search.aspx?language_code=en&country_code=us&SearchType=SSP
I can tell for sure that the warranty for this specific model M2727nf will be extended 1 extra year (means you have 2 years coverage) if the printer has a scanner error 5. I Hope this can help ...
You can contact me directly on : [email protected]
SOURCE: I have Networked hp model M2727nf all-in-one
This is due to a formatter failure.
Try an nvram
if this does not work contact hp, if within 2 years from the purchase date ask for a case number to have the printer serviced under a service note.
Al
[email protected]
SOURCE: Hp laserjet M2727nf scanner error 52
First, power the printer off, wait for about 30secs and power on. If problem persist replace the scanner.
SOURCE: Faultcode 5 for HP laserjet M2727nf The scanner
Hello, This sounds like a Scanner/Flatbed Problem. "The printer report a Scanner Error 5" This series of printers have a known problem
with this component. The scanner is failing to initialize itself. The scanner
does need to be changed by an Authorized HP Warranty Repair Facility. It is
possible that it may be covered under an HP Extended Warranty program. See
repair information VIA posted Link.
Cheers!!
SOURCE: HP Laserjet M2727nf Mfp Printer Scanner Error 8
The HP M2727 has a known issue with the scanner error 8 and bad formatters. HP has extended the warranties on this product. I suggest you contact them directly and they will most likely exchange the unit.
Cheers!!
