LG WM-2277HW Front Load Washer Logo
Posted on Apr 15, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Balancing I need to balance my front loading LG washer, besides leveling it, is there a way to "test" run th espin cycle to insure proper balance?
Anonymous
Level 2:
Novelist:
  • Expert 142 Answers
  • Posted on Apr 15, 2008
Anonymous
Expert
Level 2:
Novelist:
Answers
142
Questions
0
Helped
88884
Points
347
This type of thing should not be required. Front load washing machines (well, topload too i guess) will balance themselves out for the spin cycle unless the machine is grossly overloaded.
Good luck.
1helpful
LG front load washer makes thumping sound in spin cycle. It sounds like fun rubs when machine is filling . It is not off balance.
Hello..
Check the machine legs and ground level properly, and also dont put a single blanket or a single weight cloth sure it will make noise..
1helpful
I have an lg front load washer and on the spin cycle it vibrates very loud and seems not to be balanced. Washer is level and does this regardless of load size
there are 3 shock absorbers attached to the drum. they may need replacing. check out the videos on either applicancepartspros.com or repairclinic.com
My front load LG Tromm doesn't spin but turns left and right when in first cycles.
CALLED LOAD SENSING UNIT IS TRYING TO BALANCE LOAD IS WASHER LEVEL.... TRY ADDING CLOTHES TO WASHER TO EVENLY COAT TUB FOR EVEN SPIN
1helpful
Excessive drum vibration
Yes, look into trading in the Kenmore for one of only two manufacturers that employ a dynamic balance system built into the washer drum. Samsung and LG both use this dynamic balance system that balances the load while it is in motion. They also use a vibration sensing system to modify the time and speed of the spin cycles to minimize any vibration that might still be present. LG has this available on only their upper level models while Samsung's VRT is available on most all models. I believe that both of these manufacturer's are available from Sears.
Error code UE on LG Front Loading Washing Maching
this is what i just found on the internet...
With any washing machine, it is vital to ensure that the load is evenly balanced when using a spin cycle. Redistribute washing by adding or removing items to ensure a more balanced load. ... If the door remains locked and the machine is displaying UE error, please run a drain program.5 Jul 2016
My Samsung washing machine is showing a UE code during a spin ...
or try this link..
Error code UE on LG Front Loading Washing Maching Google Search
3helpful
2answers
LG TROMM noise during spin cycle
Dear Customer,
for ur water not drainin out, please do the the followin checks
  • Inspect the drain hose for kinks
  • Test the timer control
  • Test the lid switch
  • Inspect the water pump
  • Inspect the drive belt (belt drive only)
  • Inspect the motor coupler
  • n for ur rattling during spin cycle please do the followin checks..
    Please read our safety information before attempting any testing or repairs
    Before working on the washer, unplug the appliance or shut off the power at the fuse box or breaker panel to avoid an electrical shock hazard.
    A washing machine may wiggle, rattle or move across the floor. It is often accompanied by excessive noise. There can be several causes and the problem is worse with some machines more than others.
    The most common cause is an unbalanced wash load. Open the lid and when it comes to a stop, redistribute the clothing to balance the weight. Heavy loads, especially things like comforters, are more likely to become unbalanced than small loads. If you do a lot of heavy loads, you should consider a heavy duty/large capacity washer when it comes time to replace your current unit.
    A washer must be level both from side to side as well as from front to back. Washing machines have adjustable feet to enable you to level them. See our article on how to level your washing machine.
    The outer tub is supported by springs, pistons or counterweights to keep it balanced. The weight of all that water in a wash load requires a powerful balancing mechanism. If the balancing system becomes detached from one or more points, it will not be able to balance the load properly. Furthermore, even if everything appears to be in place, as the appliance ages, the springs or pistons may begin to wear out and not support as much weigh as needed.
    Unplug the washer and open the cabinet. Because of the variety of balancing mechanisms, you will have to inspect your machine to determine how it is balanced. Once you discover the mechanism, then inspect it for integrity. In the case of old parts that appear to be in working order, you may not be able to tell if they need to be replaced. They may be weak but appear to be in good condition. If no other solution resolves the problem, then replacing the balancing springs or other moving support parts may be called for.
    Another common cause for excessive movement is the floor on which the washer rests. The washer is heavy and even more so when filled with water. Any floor, other than a concrete slab, will tend to pick up and amplify the vibrations from the machine.
    There are a couple things you can try. If you have access to the joists under the floor, you may be able to beef up the support. Another thing to try is placing a large sheet of plywood under the washer. It should be 3/4" or even 1" thick and as large as possible to distribute the weight. Use a sheet big enough for both the washer and dryer to sit on. If possible fasten the plywood to the existing floor.
    • General tips mentioned above
    • Balance the load
    • Level the machine
    • Inspect the water pump for a blockage
    • Inspect the coupling
    • Inspect the transmission
    • Adjust the drive belt tension
    • Check the motor bearings
    • Check the drum brakes
    Please rate this solution.Thank you..
    Kenmore Waher spin cycle out of balance
    Sounds like your front to back spring is pulling to tight, sometimes you need to replace it and sometimes you can take it off and stretch it. hope this helps
    Top LG Washing Machines Experts
    Mike Cairns
    Mike Cairns
    ZJ Limited
    ZJ Limited
    Are you a LG Washing Machine Expert? Answer questions, earn points and help others
