I hear the dishwasher humming, and the water is on at the faucet, but the dishwasher never fills.
Hi
Thanks
for using FixYa. To start with check the water inlet valve which is located
behind the lower access panel on the left or right side of the Dishwasher. If
the water inlet valve is bad you have to replace it, also check the main water
line for clogs/obstructions. If still the issue is not resolved then it’s a bad
float switch and needs to be replaced. Please do rate the solution if the
issue is resolved or post a comment for further assistance.
Thanks
Rylee
Hello &
Welcome to FixYa
When the
dishwasher fills then it means that the control and the water inlet valve are
fine, hum sound itself indicates that the motor is bad and needs replacement.
If you hear a hum sound from the bottom of the unit then it is the motor that
is bad and if the hum comes from the control then it is the timer that is bad
and needs replacement. Please get back to me if you have any other questions.
Kevin
