Lands Phones Logo
Posted on Jun 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a prostar samsung 816 plus and we have a number of phones in the office and only one is ringing, how can I make them all ring?
  • Gene Fields
    Gene Fields Nov 18, 2014
    after reprogramming phone per george peters light still flashes with an incoming call and no ring tone
  • Gene Fields
    any other thoughts
george peters
Level 3:
President:
  • Master 860 Answers
  • Posted on Jun 24, 2010
george  peters
Master
Level 3:
President:
Answers
860
Questions
0
Helped
609366
Points
3471
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down, enter #20 the screen should say MMC DISABLED
enter in 1 2 3 4 1 # (that enables programming)
enter in #62 the screen should say day ring assn
press the line you wish to program
press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
press # when finished with the line
repeat steps 2 through 5 for the remainder of the lines you wish to change
press # when finished.
  • george  peters
    george peters Jun 25, 2010
    Any luck with programming the ringing?
  • hnggirl Oct 04, 2010
    HI, I am having the same problem, but the fix didn't work for me. Any other ideas? THANKS
5 Related Answers
Anonymous
  • 213 Answers
  • Posted on May 04, 2011
SOURCE: I have a prostar samsung 816 plus and we have a
Hi, have you checked that the number is ringing at a group? to do this enter customer programming;
TRSF 200
1234
1 to enable
press your speaker key
enter 714
The screen will display;
DID DGT (001)
DGT : XXXXX
Press the volume key until you get to the number you wish to program, when you have reached this press the 3rd soft key under the screen (TAB) until you get to the DDI Destination which will display:
1 : XXX 2 : XXX
Enter the extension number OR the group number which you want this DDI to ring at. (1= day ring plan , 2= night ring plan, unless other ring plans are in place on the system )
Once you have put the group in you need to go to 601 to enter all extensions into that group. If you visit http://www.abbeytelecom.com there are easy to follow videos covering a wide range of programming issues on the Samsung phone systems, I have uploaded one which I think will help, regards
consultel1
george peters
  • 860 Answers
  • Posted on Mar 21, 2009
SOURCE: samsung prostar 816 plus system ringing problem
sounds like your having a couple of problems at the same time. the lines only ringing at station 1 is the default setting of the system my guess is that the time and date are also way off if thats the case.
with the handset down enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #62 the screen should say day ring assn
3) press the line you wish to program
4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
5) press # when finished with the line
6) repeat steps 2 through 5 for the remainder of the lines you wish to change
press #when finished.
next, the problem with the cordless not working has to do with the port programming, in default it assigns all ports as multiline sets.
To assign a SLT(single line telephone) port to the system while still in program mode dial #38 the screen should say slt dial type and then 16 0's.
0 = keyset 1=slt set
enter in all 16 digits followed by the # i.e.if your cordless is on port 7 it would look like 0000001000000000 #
lastly the phone that can no lnger recieve calls sounds like the do not disturb or DND has been pressed to stop the alarm from ringing. press the mute/dnd button (light should be off). to cancel an alarm press the ALM/SD button twice and then the hold button.
hope that helps out.
joe phones
  • Posted on May 07, 2008
SOURCE: Samsung Prostar 816
The battery is dead and will not maintain system programing after a power outage. If the battery is not replaced this problem will occur everytime the power goes out.
ginko
Ginko
  • 19396 Answers
  • Posted on Aug 12, 2008
Did you try unplugging power cord for five minutes? often this fix the problem.
consultel1
george peters
  • 860 Answers
  • Posted on Feb 13, 2009
The code for hold recall is #52
enter in your hold recall time in sec. and in a 3 digit format. i.e. 30 seconds = 030 a minute and a half is 090 and so on.
it sounds like the memory battery on the main board is no longer working which means that it'll happen again.
How do I change the hold time before it rings back on my prostar 816 plus?
root your phone and edit call ring delay in build.prop in the root of your phones system storage.
Samsung Prostar 816
I have a prostar samsung 816 plus and we have a number of phones in the office and only one is ringing, how can I make them all ring? I have followed the instructions in the manual and the following...
TRSF 200
1234
1 to enable
enter 714
DID DGT (001)
DGT : XXXXX
1 : XXX 2 : XXX
3helpful
After a series of power outages and brown outs over the weekend, our system has lost all of the predialed #'s and only one phone in the whole office (10 phone) rings.
Sounds like the system defaulted programming.
Depending on the type of prostar 616 the only ringing station would be 1(or 21) with the porstar or 4(or 24) with the prostar plus.
To program system speed dial numbersyou need the customer programming enabled (see the first part of programing ringing)
dial the 2 digit speed dialcode 10-98
dial the telephone number to be stored in that speed dial bank
press ALM/SD to store the number
3helpful
Secondary phones will not ring
with the handset2.gif down enter #20 the screen should say MMC DISABLED
2) enter in #62 the screen should say day ring2.gif assn
press #when finished. hope that helps
Does not ring
Hi Sandra, this sounds like your phone that is not ringing needs to be added to a group- I have sent you a video showing how to do this. go to www.abbeytelecom.com for more training videos relating to the Prostar 816
16helpful
Samsung prostar 816 plus system ringing problem
4helpful
Samsung Prostar 816
Samsung Prostar 816
Top Samsung Lands Phones Experts
Ngoro
john h
ADMIN Andrew
ADMIN Andrew
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
