There will always be some residual water left in the outer tub after draining. This is normal for most washers. Purchase a container of Oxy-clean and cycle the washer a few times using hot water settings with a half-cup of Oxy-clean added to each cycle. This will help remove any organic matter left behind that might be causing odors.
if it spins when you remove the wieght out of the tub i'd change the belt and if that's not the problem the tranny is bad but try the belt first,most likely that's what it will be,stop overloading the washer the part number for the belt is 25001054 and it's around 15 bucks
i have maytag neptune mah6700 and dosent rince good in the end of each wash the cloths steell to mutch water in the cloths dosent rince it good i thing the speed of the spin not that strong and the motor its very good but i thing is someone played with the fron the code and i dont have the manual to check those code
If the washer is removing all of the water from the washer during the spin cycle it is likely working properly. Not an expert but I believe max extract causes the washer to spin for a slightly longer period of time in order to remove more water from the clothes. We use it regularly because our clothes come out to wet otherwise.
It will not spin while washing, it's more of a rocking back and forth. As far as the spin cycle. If it's not reaching full speed I bet you'll notice that it's not doing the full cycle because the load is bouncing around and cause the washer to shut off. take some of the clothes out and watch it spin the water out.
Maytag washer parts, GE washer parts, and other brand names on the market are all designed to work interdependently with each other. This system starts to break down if even one part begins to encounter difficulty. Your washer's spin cycle flings a large amount of water out of the clothes, but if the water can't drain, the clothes will soak it all back up, defeating the purpose of the cycle. Excessively wet clothes after the spin cycle may not be caused by faulty washer parts, but rather a blocked drain is a very good bet. Check the drain line for a blockage and try again. If your hose is kinked or bent, this can also cause a drainage problem. The failure of one simple part creates a larger problem for all the washer parts. What can cause a blockage? A number of items; paper left in the pockets of your jeans, coins or other debris, even socks. Check your hoses, and make sure your laundry has empty pockets for future loads.
If there's
a loud thumping noise during the spin cycle, the load of clothes has
probably gotten unbalanced. Open the lid, redistribute the clothes in
the washer, then re-start it. Repeat these steps if necessary.
