Re: How do you remove the filter cover on stylus spa bath
It is not a filter cover but a suction line cover. If there are no screw heads showing on the front of the cover it will either screw on or snap on. Be careful when you pry as they are fragile and can crack or break, take your time.
the main problem is body oil and grease
there are many cleaners that will remove that and a product like Gumption will remove and white scale around the bath at water level
spa baths should be cleaned very regularly as they harbor a large number of germs form the bodies that use them
In fact medical professionals around the world are against spa baths in hotels as they are seldom cleaned properly thus transfereing many diseases
? 6:49
https://www.youtube.com/watch?v=GbyHTxzTabY
Mar 15, 2012 - Uploaded by Mrsdarkness2011
Review of hot spa by Helen of troy .... i have this same foot spa. pros: is it can heat cold water, cons: doesn't have adjustable heat temp, not ...
An unbiased review of the Helen Of Troy Hotspa Pro foot bath. Helen Of Troy offers several professional foot spa products and this foot bath has one of the.
Dedicated to delighting the consumer. We aim to make reliable & long lasting products. However, in the unlikely event that your appliance requires servicing ..
DE filter? If so then you need to give the filter an acid bath to purge the dead alge from the filter (Fingers, Grids or Discs). Go with 1part muriatic acid to 3 part water. Let soak overnight. The water should turn almost neon green.Rinse off and reassemble. SHould be Good to go. DE and Cartridge filters should be given an acid bath once a year.
hook up a garden hose to a faucet. Put the other end in your spa. Then turn on the faucetuntil water comes out the spa end of hose. Make sure the end in the spa is weighted down so it doesn't come out. Then remove the hose from the faucet and keeping it lower than the spa lay the hose where it can drain with causing problems. The water will flow on its own draining the spa. You may want to clean it while its draing so the dirty water will be diluted and drain at thhe same time. Make sure the water is not drained out around any electrical AND!!! NO DIVING!!!! If you lose the prime, just fill the hose again with the faucet. Good luck
Your circulation pump isn't working you should see the flow awitch closing if you have the visible model and hear the pump running.. If its the smaller circulation pump model it needs replacing
