Unfortunately there are no known ways to change the user code. The parental controls are set because it's a DVD player for kids - and you must input the password every time you want to play a DVD.
1369 is the code to allow you to play blocked movies. I still
haven't found a way to change the level. Again, you have to input the code each
time. I know it stinks, but I guess they didn't think of the parental feature in its entirety.
Same problems with my unit. But, try this... I think it worked. First, you can not get to the setup screen for the unit with a DVD in the player. So, remove the DVD first: Unplug the unit, wait a few seconds, plug it back in. Then hit the DVD open button and remove DVD in player.
I think the issue with not reading certain DVDs is a problem with the "parental control" on the unit. Without setting parental control there were a few DVDs I could not play and sometimes (not always) I was asked about parental control before a movie would play. At the Sony Blue DVD screen, select Setup on the remote control. Select DVD setup and get to Parental control. Set a password. This will then take you to a "rating" screen. By setting the rating very high (I set mine for #8) any movie should play without needing the password. With no password set, you can not change the "rating" and hence mine was set at #1 (kids). It seems to have worked for now anyway. Good luck.
