Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
Posted on Jun 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Frigidale 10 years old stove bottom heating
Frigidale 10 years old oven bottom heating element stop working; disconnected element and checked resistance - exactly 20om, connected tester to wires (heating element disconnected), turn ON oven - voltage is 96V?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 05, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
582
Points
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Ron Welts
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jun 18, 2014
Ron Welts
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1097
Points
I had the same problem with good element....the clock on my stove does not work and the timer was moved and the bottom oven stopped working...I played with the timer and got it working
Fix Your Board
Level 3:
Guru:
  • Master 310 Answers
  • Posted on Jun 23, 2010
 Fix Your Board
Master
Level 3:
Guru:
Answers
310
Questions
0
Helped
124211
Points
1016
Bake relay is worn out. Relay is part of the oven control board. This can be repaired: http://www.fixyourboard.com/index.html
1helpful
The main oven doesn't heat but the main oven grill function does heat up! I'm not sure if this means the element is no longer working or if it is a problem with the control switch?
Make sure the power is off, then there should be two screws holding the element to the back wall remove them. Pull the element out until you can get to the wires, sometimes a wire will burn off at the connector, if that's the case replace it with a high temp connector if not disconnect both wires and do a continuity check on the element
Apr 14, 2015 • Ovens
The stove is 26 years old. Has been working very well. Now the two heating elements on the left side of the stove and oven are not working. The pilot lights come on. Fuses in good shape and 220 volts...
check the contact points on the rear of the element they burn off after years of use, if the contacts are still good, Look at the element itself for any white marks on the element, if you see any , the element itself has probably burned out and need replacing , to get to the contacts,, depending on the oven, remove the back they should be right in sight , if you do need to replace the fittings on the wire ends, be sure and get heat range connectors
May 29, 2011 • Ovens
2answers
The oven will not light on my Whirlpool gas oven Mod SF368LEPQ 2. The stove top burners still light.
Sounds like you need an bake element ignitor if the bake doesn't work but if the broil also doesn't work, it could be the electronic clock/timer control. the part number for the bake ignitor is 8054129 .Best off to call a reliable service company such as Sears.
1helpful
Electric Oven is not heating up (BAKE)
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} It could be that your lower element is burnt out or ready to burn out. They last 3-5 years depending how much you use your stove.
Disconnect POWER to the stove, remove the screws holding the lower element to the back of the inside of the stove, pull out carefully and remove the 2 screws holding the wires on. Check the element with an ohm meter, it should read 0 (zero or very close) resistance on an ohm meter. You may also take it to a store that sells replacements ($25) and they may check it for you.
Nov 13, 2009 • Ovens
2helpful
The fan and oven light in bottom oven works but not heat.
The heating element is the likely culprit as they burn out and go open
circuit..(ie ...disconnected and will not heat up )
If you can use a multi-meter , then the element can be tested using the resistance range (with the oven SWITCHED OFF )
8helpful
Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Wierd problem with ge eletric oven / no heat
check the electrial connection at the back of the range, also check the breaker
Heating element in GE Range Oven
get the model number and order the exact repacement bake element
Top Frigidaire Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Kell Le
Level 1 Expert
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
