Question about Netopia 3-D Reach (TER/GUSB-N1) (TERGUSBN1) 802.11g/b Wireless Adapter
My wireless adapter doesn't pick up any wireless networks.
I have a new modem and when I connected my wireless adapter it worked the first time but when I turned on my computer the next day the wireless adapter did not pick up any wireless networks. I know that my Modem works because My laptop and iTouch can connect to the network.Is there a way i can fix the wireless adapter?
SOURCE:
acdr
  • 1913 Answers
SOURCE: wireless network adapter(code 10) and pci modem (code 28)
install proper driver then set ip adress .
enable wireless adapter.
Posted on Oct 07, 2008
SOURCE: having problems with the security key/passphrase
u will be able to find the secutiry key at the back of ur modem or at the router page. let me know the router name if unable to find the wireless key still
Posted on Nov 13, 2008
SOURCE: how do i connect the adaptor to my computer?
lol
Posted on Apr 01, 2009
  • 6 Answers
SOURCE: desktop icon shows wireless network is connected
maybe work offline is activated?
Posted on Apr 14, 2010
domotek
  • 591 Answers
SOURCE: i have a netopia usb
Try to update the wireless card's driver to the latest version using the manufacturer's web site or windows update manager...
Enjoy!
Posted on Jan 04, 2011
My laptop will not connect thru the ethernet cord to my modem, I think the network adapter got zapped during a storm but when I troubleshoot thru the laptop it says that the device is working properly -...
I went through several modems in a week due to a multitude of lightning hits. My modem always reported itself as fine, but it never worked. I would guess that your old machine doesn't use some feature which was destroyed. I would try to find a cheap adapter; they can be found for $10 or so.
-bin
Aug 25, 2011 | Dell lp-n21063-b Network Adapter
Earlier today I was connected to the internet fine. I stepped away from my computer for a little bit and now it doesn't connect to the internet. The wireless adapter is showing that it is connected to...
Here are some troubleshooting steps that you can do so you can isolate whether the problem is with the router , the modem or your pc.
1. Disable / enable the wireless connectivity in your laptop.2. Restart the laptop. Then check if it is working. If not, go to the next step.
3. Restart your modem and router by unplugging the power cord on the back of the devices. Wait for the devices to load, then check if it is working. If not, proceed to the next step.
4. Try connecting your laptop to the modem directly by using an ethernet cable. If it did work, the problem is with the router. Its best to call the manufacturer of your wireless router if that's the case.
5. If step 5 still didnt work when you already connected your laptop directly to the modem, the problem is with the modem itself. Call your internet service provider and they'll do troubleshooting steps on their end too.
Hope this was helpful! Have a great day.
May 27, 2011 | Netopia 3-D Reach (TER/GUSB-N1)...
The wireless network is being picked up by the laptops in the house, but there is no internet connection between the modem and the router. MY router is a Belkin G Wireless
if you connect the computer directly to the modem, does it work?
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Mar 06, 2010 | Belkin Wireless-G Plus MIMO Router with...
Wireless adapter will connect to router for a while, then connection quits. Sometimes it stays on for a while - other times not for very long. Lights on the modem stay on but connection does not return -...
Hi there, sounds like you need to sync your modem and router. First turn off the power to the modem, then to the router. After a few minutes reinstall the power to the Modem then to the Router. Restart your computer and see if you now can connect. Good Luck...
Oct 22, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Configure Modem Echolife HG520s With WRT54G OR WRE54G
Not sure if I understand properly but your router should have a WAN port or an "Internet" port
your modem should be connected to it and your PC should be on any of the LAN port
Apr 04, 2009 | Linksys Wireless-G WRT54G Router
How can I install a wireless usb adapter WG1111....
First put in the cd that came with the wireless USB adapter. Close the auto setup page(we will use windows wireless network manager which works better with windows firewall . Plug in the wireless adapter and the laptop will automatically install the driver. If for some strange reason it asks you to install new found hardware, follow the promts and install manually and select cd and the directory the WG1111 drivers are located. Press ok and wait for install. Restart the computer.
After restart the computer will come up with a caption New Wireless Networks found. Double click on the wireless Icon in the bottom left hand corner. It will open a seperate screen with all wireless connections avaliable to you. Might be 1 or more networks, depending on whether your neighbours have wireless networks. Anyway find your specific wireless network could be for example NetGear, Dlink, or my home network. Click on connect your wireless connection. Another smaller screen will appear with Key in your password twice( WEP key or WPA key)
Key in your key or password twice and apply or ok. It will connect and close screen.
Restart computer!
After restart the computer will pick up your connection automatically and your ready to go on line. If you move your mouse down to the icon with wireless network in bottom left hand corner it will show your wireless connection in a caption stating the connection name and how strogn signal is. Connection complete.
NOTE: YOU MUST HAVE A WIRELESS MODEM OR WIRELESS HUB CONNECTED TO YOU MODEM TO USE THE WIRELESS WG1111. THANKS!
Aug 02, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
New pc, with wirless adapter,
look in your manual, turn off your internal modem, wifi. and then plug in your new adapter. restart and see how that works. if not then best buy has a great tec department
May 13, 2008 | Computers & Internet
Wireless connection
If this laptop has a wireless switch, make sure it's on.
Did you get the wireless hub?
Wireless is controlled by the wireless zero service, which should turn on automatically when your adapter is detected.
You can turn it on manually in Control Panel/Admin Tools/Services
Nov 03, 2007 | Acer Aspire 3000 Notebook
Netopia 3-D Reach  (TER/GUSB-N1) (TERGUSBN1) 802.11g/b Wireless Adapter Logo
73 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
marty morrison
marty morrison
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
