I have a mitsubishi wd-y65, never had any problems. When I turn it on the green light comes on the fans start running and the tv sounds like it is powering up but the picture never comes on and after about 30 to 60 seconds of trying to power up the tv turns itself off. Everytime I turn it on this same thing happens. I unplugged it, reset it, took the back panel off and cleaned the vents, and checked the lamp. The lamp wasnt discolored and the inside didnt seem to be warped as far as I could tell. Can anyone help?
SOURCE: What causes my mitsubishi WD-Y65 tv to keep
thermal sensor problem.... there is a service bulliteen to service shops about this.. this generally a warranty item that is covered.... you will have to get a tech to see if its covered. the thermal sensor needs replaces.not to difficult to replaced
SOURCE: my mitsubishi wd-y65 has sound but screen is black
You are SURE the lamp is good....well...if you say so. However, it sounds like you have made audio connection but no video connection (or lost it or is incorrectly set). Try other input modes. See if you an bring up "setup". If so...you screen/lamp is working.
SOURCE: hdmi 2 wont work on mitsubishi wd-y65
It sounds similiar to a problem we've had with ours, all components would work in hdmi 1, but hdmi 2 would only work intermitently. They ended up replacing the digital board (fortunately we have the extended warrenty, I'm sure it's not cheap). Sorry hope this helps.
SOURCE: How do I replace the
hofferberr,
I have a tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which explains how to change the lamp, why when to change the lamp and where to get the best lamp at the best price.
Thanks for using FixYa and for the great rating.
hardrocko
