Question about NorStar Meridian M7310 Phone
F 981 Hello, we are trying to set-up voicemail with our Norstar M7310 and Feature 981 is not recognized...am i missing something or a set-up? Thanks Ana
    President:
  • NorStar Master
  • 860 Answers
If none of your voicemail feature codes(f980-f989) are active, then that means that the system doesn't recognize any nortel voicemail on the system.Which means that a) your system has a non-nortel voicemail system attached to it, b) theres no voicemail attached to the system at all or c) the voicemail is no longer functioning.
Posted on Jun 23, 2010
SOURCE:
Norstar m7310... tried to reset password using feature 983, now can't get any feature numbers to work. I dial feature 9 8 and the display goes blank. Any suggestions?
yes it is feature 981 after you get the screen to show something like pass word then log in to it the when you press 8 then 4 you can the change your password.
Nov 14, 2014 | Nortel Norstar M7310 Telephone
Don't know password
feature 983
it will say log- press 1020000
it will say password-under that it says reset-push that soft key!! press release.
default will be 0000 once you access voicemail(981)
Jan 14, 2013 | NorStar M7310 Phone
When I press "Feature 981"
The inactive feature response means that the phone system and the voicemail are not communicating with each other. I would first check that the voicemail is powered on. If it does have power, I would reboot it by unplugging it for a minute and then plugging it back in(startup can take 15 minutes).StarTalk, Flash, and NAM are some of the names of the voicemail units for small to medium size Norstar phone systems. Occasionally, both the phone system and voicemail need to be rebooted to allow the two to sync up and "see" each other. Occasionally the Norstar voicemails go bad where they will not power up or after powering up they cannot complete the boot up process or after powering on and booting up they will not answer when called. If your unit will not work after trying to reboot a few times, I would recommend you consider having the unit repaired before replacing it. If you need advice on where to send for repair, send a comment and I will help.
Feb 23, 2011 | NorStar M7310 Corded Phone
When I check voicemail it says Flash busy and I can't enter the password..
They would be logged into the voicemail either using the open voicemail key or feature 981. It's a good guess that they aren't.
How long has the voicemail been tied up?
May 26, 2010 | NorStar M7310 Corded Phone
Old alternative greeting showed up
Sounds like he turned on the alternate greeting. to change the greeting back to the primary greeting.press open voicemail (or feature 981),enter in your password and press ok,
Press ADMIN or 8
Press GREET or 2,
Press CHOOSE or 2,
Press PRIME or 1,
Press Rls when finished
Mar 31, 2010 | NorStar M7310 Corded Phone
I have M7310 phones with the complete system I can not seem to be able to activate our mail box system, we tried entering f:981 and F:983 however it says feature inactive
If none of the voice mail feature codes work (feature 980-989) then the voice mail system is either not working or isn't recognized by the telephone system.Go to your communications closet and check to see if theres a power light on in the voicemail.If not then you might want to call in your tele system service provider.
Jan 15, 2010 | NorStar Meridian M7310 Phone
When i hit the "vmail" button it beeps and says incoming only
That button is not programmed for voicemail, sounds like someone was playing and gave you a Target Line...
Press FEATURE * 0...
then the button that is giving you issues...
If the button says ex: 145 Line 145 that is a target line...
If you see Feature 981 that means voicemail.
My guess is someone gave you a Direct Inward Dial [DID] (a direct number) to your set.
Mar 04, 2009 | NorStar Meridian M7310 Phone
Norstar: Inactive Feature (981)
This generally happens from one of two things. Your voice mail system is connected to your phone system through a station port. If it loses connection it will not communicate with the phone system. Loose wire or connection can cause this. or it has just crashed and will need repair or replacement.
First thing you want to do is unplug the unit wait 15 minutes and plug it back in. wait 10 minutes Try feature 981 from a set that has voicemail. if nothing. hit feature 985 from a m7310 set or a m7324 set not a m7208. If it comes back with inactive fearture now your connection between the units is bad or the unit itself is bad. If it comes back with the voicemail intercom # and you cant get into any mailboxes it has lost all programming.Try this first.
Oct 10, 2008 | NorStar M7324 Telephone
Resetting company voicemail
Norstar Common Voicemail Features To Check Your Voicemail:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. From here you can listen to messages, change your greeting, change your password, etc.
To Leave a Message for Someone in Your Office:
1. Press the Leave Message key or Feature 980
2. Enter the mailbox number (extension number. of the person you want to leave a message for
3. The display will show the name of the mailbox owner, press OK
4. Leave message
To Access Your Voicemail box from Another Phone:
2. Press the OTHER softkey
3. At the LOG: prompt, enter your mailbox#(extension #. and your password all together followed by the "#" sign
4. Press the OK softkey
To Access Your Mailbox from Outside of the Office:
1. Call the main office number or your DID (if applicable.
2. If the call is answered by a receptionist, have them transfer you to your voicemail box
3. If the call is answered by the company greeting, or your personal greeting, Enter: * *
4. At the prompt, enter your mailbox #(extension #. and password all together
To Transfer Someone to a Voicemail Box:
1. Press the Transfer to Voicemail key or press the Feature button, then 986
2. Enter the mailbox # (extension#.
3. The display will show: Call Transferred
To Change Your Personal Greeting:
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
To Record Your Alternate Greeting (Used when on vacation or out of the office.:
5. Pres the REC softkey
6. Press the ALT softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording, then the OK softkey again to accept the new recording.
9. You then need to have your voicemail box now play the Alternate Greeting, Press the GREET softkey
10. Press the ChOOSE softkey
11. Press ALT softkey
12. Display will show: "Accept msgs: Y", Press the OK softkey to have your voicemail box accept messages while your Alternate Greeting is turned on, or press the CHNG softkey to change the "Y" to an "N" if you do not want your voicemail box to accept messages.
13. When you return to the office, make sure you go back into your voicemail box and have it play the PRIME greeting
took this from a guide i have, might help you guys out
Jan 07, 2008 | NorStar M7310 Corded Phone
NorStar Meridian M7310 Phone Logo
673 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
pbxinc
syaiful ridlo
syaiful ridlo
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
