Turn the D32xd on, it then says fatal: powerOn error and asks if you want to initialize. That you cannot do, as it then says hard drive format error or something and powers down.
Generally, a hard reset is initiated by pressing a dedicated reset button, or holding a combination of buttons on some mobile devices. Devices may not have a dedicated Reset button, but have the user hold the power button to cut power, which the user can then turn the computer back on.
It is asking for confirmation that you want to initialize the unit. The manual doesn't say anything about this... but you should try pressing the "Yes" button to confirm you want to initiallize the unit or press no if you want to staart without initializing.
Did you POSSIBLY try to do a firmware update and crash during the process? If so, then the OS is probably fatally clobered and you will have to send unit to a place to do a factory RESTORE. You should try a factory RESET first however. Do these:
First thing would be to check the power supply voltages. It may be the disk drive is failing. Drives are inexpensive, might be worth a try with a new drive. Also check that cables to the drive have not been loosend by handling.
before you go out and buy a new hd try intializing your system.
unfortunaly you will lose all saved info, but you will either way. this test may save you some money.
with your 1180 in the off position press and hold the track 5 button below the fader and the redo/undo button that is just to the left of the rotarty knob and below the power button. while holding these two buttons press the power button and continue to hold the track 5 button and the undo redo buttons untill the test menu is showing. its takes about 15- 30 sec. in the test menu rotate the value knob till you see 23 initialize HDD and press ok. this process may take up to 30 mins. if this doesnt fixya then contact roland for a replacement.
