The wire to the carb bowl is a fuel shut-off solenoid. Needs battery voltage applied while the engine is starting/running. Your ignition switch will need a 'load' connection (battery voltage when 'ON' or 'START', off otherwise.
If your ignition switch is not suitable, you will have to rig something.
