iRobot 5900 Scooba Robotic Wet/Dry Vacuum Logo
Anonymous Posted on Jun 23, 2010
Scooba will not start clean cycle...the battery is fully charges and the power light is on but the clean light will not come on and it will not start cleaning...scooba also does not make any noise or beeps. what is wrong and how can i fix this?
  • Anonymous Jun 23, 2010
    no this was not helpful at all...i have my manual that came with my scooba and page 21 does not help my problem....i can't believe i wasted my money on this...this is a ripe off....
Anonymous
Level 2:
Genius:
  • Expert 1,040 Answers
  • Posted on Jun 23, 2010
Anonymous
Expert
Level 2:
Genius:
Answers
1040
Questions
6
Helped
289760
Points
144
Visit to the given link and download the manul. Manual gives the solutions, which can be applied at home... (Especially go through manual's page no 21)...
http://www.irobot.com/images/consumer/cs/Scooba_Manual.pdf
Hope this has helped you... Thank you
1helpful
Scooba beeps 4 times
  • Lift Roomba off the floor and place it in the center of the room and restart the clean cycle.
  • If Roomba did not resume cleaning, lift Roomba and turn it over.* Inspect the Side Wheels for dirt or obstructions.
  • Test the Side Wheels by pushing them in and out and making sure they rotate freely. Place Roomba in the center of the room and restart the clean cycle..
  • 0helpful
    Hello. My scooba 5800 had a check tank light on. I used a straw on the valve and that fixed the problem. Now the scooba runs like nothing is wrong, but there is no actual cleaning going on! It goes the...
    Hello, Take the battery out and hold the switch down for 30 seconds, to reset the curcuit board, then charge back up for 12 hours. this should take care of it. If I can help future please call @ 1561-848-3387 Thank you, Teresa. Clean Sweep Vacuums
    2helpful
    2answers
    It leaves water after finished. That's the first time I use it but it leave water on the floor and it stops.
    According to iRobot make sure that the Scooba is clean, including the parts (vacuum hose & filter, bottom roller)
    Make sure the battery if fully charged, and that you let it complete the cycles!
    1helpful
    Have Scooba 340 that won't power on after battery fully charged!
    No repair services anywhere, unfortunately. It does sound like you might need a new battery, but the issue could also be the power button. I suggest giving us a call at 1-877-855-8593 so that we can more accurately determine what the problem might be and how we can most efficiently help you to solve it.
    Fembot
    iRobot Tech Support
    My iRobot scooba won't turn on after a full charge
    Do you have the charger terminal, or do you have the charger that you have to take out the battery and charge. Because I have found that my base terminal charger works better than the battery charger that needs the battery to be removed to charge.If you have the terminal charger and the power light is green when it is in the charger I would start from the terminal
    Scooba battery light turns red as soon as irobot starts
    Do you leave the battery on charge long enough? Try 4-hours up to overnight. If so, then the battery is probably at the end of it's useful life. Getting a new battery depends on cost versus life expectancy of the robot and whether it does the job you want it to do.
    1helpful
    4answers
    Scooba now stops sooner and isn't finished cleaning :-(
    I had this problem and contacted irobot. An important fact was left out of the early edition user manual to not leave the battery charging for an extended amount of time. Because of this ommision, they sent me a new battery and a software upgrade for the scooba. I just followed the directions and attached the little device they sent to do the upgrade the scooba and it fixed the battery problem.
    Hope this helps.
    2helpful
    Scooba won't turn on
    It sounds like you've got a finicky power button. Not a lot that can be done about that, but you may want to try getting your hands on the old-style Roomba remote, the black one. The power button from that will power on a Scooba, though you can't start a cleaning cycle that way. This might allow you to bypass the Scooba's power button altogether.
    Scooba 5800 Power button Red Blinking
    You probably have the manual, but here's the link to the Scooba 5800 manual anyway - just in case this would be useful to you: --> http://www.irobot.com/images/homesupport/5800_Scooba_Manual.pdf You could use a voltmeter to check the battery, but only a few months use shouldn't be enough to wear it out. If you don't have a load-tester to verify the battery's load-capacity, then you can check the voltage drop. (Assuming you can get it to contact the Scooba's circuits.) To do this, just check the battery voltage, apply a load by inserting it in the machine and turning it on, then check the battery voltage again. An excessive drop in voltage may indicate the battery needs replacing. However, the red blinking light is Scooba's indicator that it doesn't detect the battery at all. The first thing to do in this case is to clean the electrical contacts on the battery and in the Scooba. Use a damp cloth and a bit of toothpaste to rub the contacts clean on the battery and in the machine. (Toothpaste has mild abrasives in it and will clean the electric contacts without damaging them.) Make sure that both the battery and the Scooba are clean and dry before re-inserting the battery. Also, if the electric contacts in the machine are flexible matal tabs then verify that the tabs are standing up high enough to make good contact with the battery contacts. Hopefully the battery just needs it's contacts cleaned for your unit to work, but test the battery if you are sure that they are clean and seated properly to the contacts in the machine. If the battery appears to be failing, then contact www.irobot.com to cheack and see if they are still covered under your machine's warranty. Hope this helps! :)
    Top iRobot Vacuums Experts
    Oliver Street
    NOEL
    NOEL
    Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
