Steering wheel wiggles from side to side and front end vibrates under heavy braking at highway speed. Thought it might be a bad rotor or caliper but had a complete brake job done 2000 miles ago. Thought it may be a bad tire which were brand new 9000 miles ago so I rotated tires and still have same problem.
Bring the vehicle to a repair shop that has a Hunter wheel alignment rack. They will tell you what your suspension needs and do the correct alignment.
Sounds like tires and ball joints, possible control arm bushings . I need to do visual inspection and know make , year and model of vehicle to give a fairly decent diagnosis of your problem.
Sounds like you have warped rotors did they machine the rotors when they did the brake job and was it any better after the brake job or was it the same?
