Question about KLH R5100 Receiver
Connect R5100 to DVR/Monitor
I use a Time Warner cable box/DVR and want to connect my AKAI Plasma HDTV to the R5100(KLH).
Problem is I can get sound through the stero KLH but when the KLH is turned off, there is no sound from montior.
I understand there is output/input cables but am missing something here. When I had a VCR it worked fine, sound from monitor that is.
So I want to go from dvr--klh-monitor at will.
any help would be appreciated.
tks all
Use component audio to the HDTV and optical audio to your KLH reciever. The component and optical are always active at the same time. I work for TWC if you have more questions.
Posted on Aug 08, 2008
SOURCE:
How do I hook it up to a cable box?
The KLH R5100 only supports standard definition.
You would connect either composite (yellow) or S-video to the "Sat" connection on the rear of the receiver. For audio you would connect a stereo (red/white) analog connection to the same "Sat" connection.
Mar 01, 2011 | KLH R5100 Receiver
My KLH R5100 display comes and goes, most of the time is just dead, any suggestion ?
From your description you have bad connections on the display board, or intermittent power feed from the main board, it will take somebody that is handy with a soldering iron or a professional to check it out.
Dec 29, 2010 | KLH R5100 Receiver
Olevia 242 and Motorola DVR Cable Box switching
Have you tried using component cables instead. One of my Time Warner cable boxes did the same thing using HDMI.
Dec 01, 2009 | Televison & Video
When I connect HDMI from a Time Warner DVR to my Vizio thru a DVI/HDMI adapter, I get no sound. I can only get sound if I use Component input (RGB+ audio R&L). Is this a DVR issue or a Vizio issue?
Use the Time Warner remote and hit the settings button twice. Scroll down to "audio: digital out" and select HDMI. That solved it for me.
The only issue I have now is that I also have component sound outputs going from the cable box to a receiver. When I turn off the TV while the HDMI cable is hooked up to both the box and the tv the sound goes out to the receiver...
Nov 15, 2009 | Vizio P42HD Television
Klh audio video R5100 surround sound receiver
could be 2 things....
1) The receiver could be set to feed the right speaker with more volume. Check the volume setting for each individual speaker on the receiver.
2) The cable connecting the left input from your dvd player is not connected properly or is bad. Try swapping the left and right audio input cables to see if this moves the problem to the other side. If it does - get a new cable.
May 12, 2009 | KLH R5100 Receiver
P50 VIZIO WHEN ON HDTV I GET SNOW
it's probably the Time Warner cable box that have issue and not the TV. Try using a DVD player and test the same input, it should work fine.
Nov 15, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Time warner code for Fujitsu 42" tv
I have the 55 inch. try using 246. That works on mine. if not try 028,164,208,066
let me know if that works for ya
ric
another note, are you using the flash on the back of your cable box or do you have a sensor in front of the DVR box?
Nov 10, 2008 | Toshiba 36A50 36" TV
Coaxial audio cable
I need more info to help you. Is there a cable box is it a HDTV, if so what inputs are on the tv? If its a cable box what cable company, and what box kind and number?
Mar 29, 2008 | KLH R5100 Receiver
KLH R5100 Receiver Logo
452 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Gil Shultz
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
