Heating & Cooling Logo
Posted on Jun 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Air conitioner started to automatically climb in temperature, we shut the unit off, put new batteries in the remote. the uit will not turn on at all. Prior to this the unit worked perfectly. Can you help??
Anonymous
Level 2:
Novelist:
  • Expert 246 Answers
  • Posted on Jun 23, 2010
Anonymous
Expert
Level 2:
Novelist:
Answers
246
Questions
0
Helped
78818
Points
462
Since it was running (although not cooling) when you turned it off (and put batteries in the remote) it would be strange to have no power at the outlet - but I would check and make sure.
The easy way to check your outlet is - toplug something else in there - like a hair dryer or a lamp - 'assuming' your unit plugs into a regular household outlet, and is indeed a 110 volt appliance.
Step 1 - plug another appliance (hair dryer or lamp) into the outlet
If - after plugging something else into the outlet, i.e. a hairdryer and it works ok - you will - then know that there is nothing wrong with your power supply (110volt outlet). So you can move on to Step 2
Note: if the other appliance does not work - then you need to check the Circuit Breaker to see if it's tripped off. Many times circuit breakers will trip for no particular reason and just needs to be reset (turning breaker off and back on). If you find the breaker is tripped - and you reset it - and the unit - runs and cools ok - I would just keep an eye on it for a few days - watching to see if it does again. A breaker that "keeps" tripping for no apparant reason is an indicator of something electrically wrong within the unit and probably needs a Service Tech to troubleshoot it.
Step 2 - Since the power supply is ok - see if you can start the AC manually - without using the remote. If the unit will not start "manually" - I would look for a "reset button/switch" (*not all units have one) and reset it. Note: if after resetting the unit - it still does not run then proceed to next step (step 3). Or if you can't find a reset button I would look in my manual and see if it can help you find it - if, however you do not have a 'reset button/or can't locate one' then go to next step (step 3).
If - however, after resetting - "the unit comes on and -runs and cools- ok" - I would then 'turn it off,' and let it set for 5 minutes and then try operating it with the remote. If it works with the remote I would then assume you just had an 'electrical glitch' and everything should be ok. If it "doesn't work" with remote I would suspect a defective remote and replace it.
Step 3 - since you have power (at the outlet) and either have 'reset' the unit or can't locate a reset button, or there is no reset on the unit - you are now in need of a Service Tech to electrically trouble-shoot the unit to find the problem. Note: I'm assuming at this point 'Nothing' is running, - not the fan motor - or the compressor, in which case you might look for a "fuse" in the unit - again not all units have one, indeed most do not, but it's something you could check, and easily replace if it's bad.
If, after completing all the checks above and the unit still fails to come on (either manually or with remote) - then you are, as I said above, in need of a Service Tech.
hope this has helped
Skytech 3301 thermo
Check to make sure your thermostat is set at a temperature that will turn the fireplace "on".
Double-check what your "swing" temp settings are set at, as this may effect how quickly the unit shuts off because it thinks it's too close to the target temperature.
If needed:Skytech's Tech Support number is 1-888-672-8929They are available Monday to Friday, 8am to 5pm EST.
If your remote needs to be replaced, the 3301 is available here:
Skytech 3301 Fireplace Remote
If you are looking to replace it, I would also highly recommend looking at Skytech's new 3301P2 remote. It adds a programmable thermostat, and a much nicer back-lit LCD screen. This unit is available here:
Skytech 3301P2 Fireplace Remote
Our remote control will not work with our Dometic Model 57915 unit. It used to when you changed the temperature up or down you got a beep from the unit. When you push the on/off button, it used to beep...
The comfort control center requires 12 VDC . If a fuse blew that feeds 12 VDC to control box at ceiling for some reason in your panel when unplugged accidentally, that would cause the remote/wall and control box at ceiling not to communicate.
I have changed the batteries but the remote does not work. We can turn the unit on mamually at the unit but can't change temperature or any other function
Manual button in a/c unit is just for emergency. You should operate only by remote. Get new remote and operate. Helpful?
1helpful
The unit is a Kelvinator Air Con unit - Model #KSR25F-01. The unit will turn on manually but not from the remote. The remote has new batteries, but will not start the unit. The only button that the unit...
take the remote and put it in front of your cell phone.turn on the camera of your phone and push the buttons of the remote.if you see a light in your phone the remote is ok and then the eye of the pc board(is a small plate)has problem.
I have a Goodman mini-split system with a remote control. When I set the remote for a certain temperature in the summer to 80 degrees, the unit reaches that but then keeps dropping the temperature another...
How far from the unit or room do you have the remote? remember the remote is the sensor, if it isnt near the unit it will not shut off! place the remote 8 feet from the unit and leave it there, if it doesnt shut off, it was installed wrong or is malfunctioning!
4helpful
2answers
Remote does not turn on or off the Split System Air Conditioner
take your cellphone and turn on the camera,then put the remote in front of the cell and push any button.if you see the light of the remote to the cell then the remote is ok and the problem is to the eye of the plate.its a small plate in front of the split
We have lg air con, i think it is a split system. no buttons visiable. we lost the remote for it a while ago. it turned itself on an hour ago. cannot find remote want to know how to turn off?!
Find the circuit breaker of this aircon outlet or unplug the unit to outlet or wall socket to made it off. If your desire and want to shut it down.
Then final option, Find the Thermostat control (Temperature control) If its digital theres a small lcd show the number and figures that control the temperature set up to start and off the unit.
It can be done by remote only.
On the other manual way you must find also the knob and rotate it clockwise to increase the temp and run longer.If reverse counterclockwise it decrease the temp. and turn it off quickly as possible. In case if it compose of slide control. Upward to increase and downward to decrease
All aircon unit has its panel board or LCD Screen that control the power on & off.
You can test the result by trying to put a power again on the unit.
I hope you you find my solution successfull. Until you locate and found the remote.
r_ic7
4helpful
2answers
Air conitioner turns on by itself
The GE Zoneline units have small DIP switches inside the unit where you can turn various functions on or off. The units have a feature called Heat Sentinel that turns the A/C on at a certain room temperature, even when the unit is turned off. It also has a Freeze Sentinel that turns the heat on automatically, even when the unit is turned off. You can turn off the heat and freeze Sentinel features with the DIP switches in the unit. There are other features you may want to turn off. Read the owner's manual and it will tell you where the switches are and which ones turn off the features. Hope this helps.
1helpful
Air Conditioner will not turn off with remotes
Remote control has a reset button found in front or at back inside battery compartment. If you replace your remote control with battery or your remote control is malfunctioning you to reset it.
You don't have to go outside to turn off the unit, you can "on" or "off" the unit using the emergency operation switch.
Top Sharp Heating & Cooling Experts
ZJ Limited
ZJ Limited
john h
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
