Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hi : Problem with my Hotpoint WF640, Aquarious
Hi : Problem with my Hotpoint WF640, Aquarious Super Silent is: During final spinning cycle, water leakes form the front (botom ) of the machine and floods whole floor. Please guide me step by step to solve the problem. Also let me know what tools do I need to tight the inlet/ outlet connection from the supply source ? Because a pumbler left loose the connection one of the water connection which is occasionaly dripping - While he was replacing the new taps. A picture or diagram would be much helpful. Thanks. Sham...
    Scholar:
  • 154 Answers
Tools you will need:
2 Adjustable wrench's which opens up to 1"
Flat head screw driver
Philip screwdriver
Pliers
I need clarrification on which connection is leaking after the plumber replaced the new taps, but for now I will presume he replaced the isolator valves on the water lines to you washing machine.
To fix the leaky pipe open one wrench so that it fits snugly around the valve body (you may want to remove the little plastic handle of the valve) set teh other spanner on the nut which holds the pipe into the valve and rotate it in a clockwise direction to tighten, if the leak persists tunr of the water and check:
1. that there is an olive (little brass ring under the nut that the nut can tighten down onto.
2. PTFE tape or putty on the threads of the valve
Hi :  Problem with my Hotpoint WF640, Aquarious   - 57270a8.png
As for the leak on your machine this leak could be coming from anywere, the usual suspects are:
Door seal
Drum outlet
Pump assembly
Detergent Drawer
Dissconnet the power and have a look for were you see the leak, look out for limescale, rust and other water/detergent marks to help you identify were the leak is comming from. Usually you can access the back of the machine and with a torch should see the pump assembly, you can remove the top of the machine usually 3 philips screws anlong the back side of top cover then it just lifts off.
Aternativly with some help you can lean the machine backwards so that you can look under it. ONLY attempt that if you have help and you can securely hold the machine in place. Lying it down flat might damage the machine if you dont do it slowly and very carfully, if you have the original shipping bolts that came with the machine I would advise installing them to help hold the drum in place.
Hope this helps.
Posted on Jun 23, 2010
Testimonial: "Hi Thank you for your help. It gave me basic idea how to start inspection which may lead to solve the problem. Nice tips on water leaking, movement and tools. Thanks again. Sham..."
  • Daryl Williams Jun 23, 2010
    No problem, comment back if you need further assistance.
SOURCE:
My hotpoint lumina super silent is starting a cycle but only loads the water and then doesn't spin it just stays still and counts down the time until theoad finishes and then empties the water. What's...
it's not named after that other car, is it? It's a hotpoint ultima super silent. Most likely suspect is the drive belt for the tub. Remove back cover and find the tech sheet stuffed in the unit for lots of secrets, shortcuts, and commonly replaced parts with the correct mfr part numbers. Check to see if the belt has come loose and why.
Mar 05, 2015 | Hotpoint Washing Machines
WD640 aquarius super silent won't spin or drain
hi there......most likley cause is a blocked or defective drain pump....if the water cannot get out of your machine due to the faults above it wont rinse drain or spin
regards Sir Galahad
Aug 16, 2009 | Hotpoint Aquarius WD640 Front Load...
Crease reduction facility won't work
Crease reduction facility is just a slower spin cycle if you coose a delicate wash there will be no apparent difference
Mar 07, 2009 | Washing Machines
Clothes still wet after fast spin cycle
Belt loose or motor / motor control board possibly defective
Sep 13, 2017 | Hotpoint Aquarius WF000 Front Load Washer
Sounds like a loose screw/bolt/nut during the spin cycle
There is nothing wrong with your machine. Don'f bother with the sound , You said you threw 2 pair of jeans, so its bottons are causing the sound against the drum during cycle. Finished your laundry and worry no more. To make sure, throw some another clothing asides form jeans, like shirts, and feel the normal silent of your machine.
Good Luck,
Eriez
Jun 05, 2008 | Maytag Neptune MAH5500B Front Load Washer
Hotpoint Aquarius WMA56 wont drain properly water leaking onto floor
pump is working water is only a trickle coming out so wont final spin
Nov 07, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
WD640 Aquarious supersilent washer/dryer leaking from powder draw
during the rinse the machine uses a higher level of water, therefore check the door seal for holes,if the water is leaking from the soap drawer in the spin then this suggests that you may have a blockage in the outlet hose or in the sump filter, to check the filter remove the sump hose, the filter is hidden in the hose. Regards Engineer
Jul 29, 2007 | Hotpoint Aquarius WD63 Front Load...
Noisy spin loose drum
drum bearing need need bearing kit and drum support £60 plus labour at similar price. Appliance Doctor
Feb 02, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
635 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
