Check all of your speaker wire connections at both ends for looseness, strand wire fraying/breakage, correct polarity and corrosion. If all are ok, reduce your setting for the amount of bass it outputs.
1) you must get the support via ONLINE chat from the manufacturer to see if possible to play blue ray disc 2) the same way get the manufacturer some schem how to connect the speaker without the player.
I just tried this with another set of speakers and unfortunately since the iPad does not have left center or right speaker gain you will have to settle for the sound from one side level. unless you can figure out a way to splice all the speaker's configuration to a audio jack then you will have to settle for ear phone sound quality.
Try shorting across this fuse protector IP1280 (looks like a resistor)
on the
power board. See more detailed solution I posted in this forum for a
similar
question.
This DVD home theater system has a defect that is not being addressed by panasonic. The Optical lens and or DVD Motor will give out after 2 to 3 years for no reason. It will start saying "No Disc" and will not play any DVD or CD. To repair this it will cost you £100.00 to £135.00 to repair. An authorized panasonic repair company told me that if I repair this it will last me up to 3 years and I would have to fix the DVD Player again. The dvd player model number is SA-HT70 and the number for the system is SC-HT70. The SA-HT70 is the dvd player that is not reliable. Without warning in 2 to 3 years you will have to repair the optical lens or dvd motor which will not be covered by Panasonic.
