Belkin Wireless-N Wireless Router with 4-Port Switch Logo
Posted on Jun 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to change my nat setting from strict to open can't find anywhere on belkin wireless router settings
Rakesh Warrier
Level 3:
  • Master 708 Answers
  • Posted on Aug 14, 2010
Rakesh Warrier
Master
Level 3:
Answers
708
Questions
0
Helped
209432
Points
1609
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
Goto : my blog for more information about belkin routers (Page is still under construction )
Im having trouble playing xbox live due to strict NAT settings.i dont know how to change it.HELP PLEASE
You are trying to open the NAT on the router.
For this you will need to reduce the MTU settings on the router to 1365. Disable the UPnP on the router.
You will also need to trigger some ports on the router.
For this you will need to open the router set up page.
Router set up page is the page where you can change the settings of the router
Click Here to know more about router and network
3helpful
How to change the nat settings on my belkin play router from strict to open so i can play the ps3 online gameplay more easily.
what about to set the ps3 ip address on the DMZ for the router that will give all the ports open to that address and will play freely
try go to advance settings and firewall or game and applications there is where you will set dmz application .
Good luck
1helpful
My nat settings are strict and I don't know how to change them to open?
Using your Internet browser, you can access the Router’s Web-Based Advanced User Interface. In your browser, type “192.168.2.1” (do not type in anything else such as “http://” or “www”). Then press the “Enter” key.
You will get a set up page where you can disable NAT
Follow me on Twitter
2helpful
2answers
HOW DO I CHANGE MY NAT TO OPEN FROM STRICT?
redu8ce the MTU settings on the router to 1365.
you will also need to open some ports for PS3 on the router.
For this you will need to access the router set up page.
connect a computer to the router. check the IP address on the computer.
according to the default gateway open the router set up page.
Click Here for more information about the routers and network
I have a belkin wireless g router and my nat settings are strict?
I understand your problem..To fix this issue all you have to do is,You should open the x- box port numbers on the belkin router(please call tech support for assistance),
And also i would suggest you to assign static ip on x-box on belkin range(192.168.2....) then you need to enter same number on router under DMZ. It may be quiet difficult for you to do all this.please call toll free number"belkin".
Strict NAT?
If you call microsoft, and tell them that your NAT is strict, they will tell you specific ports you will need to forward. (For Free). If you arent sure how to forward ports, call up your routers manuafturer, or send me another message. I have forwarded my ports as well.
1helpful
3answers
Change NAT to open
Ok kids... all you hve to do is log in to your belkin 54g at http://192.168.2.1
Find out what ip address your xbox is using and then Click on the DMZportion of your settings on the left hand side of the page.
Enter the xbox's ip address and click the enable box.
Click apply.
Your NAT will now be OPEN!
Cheers!
3helpful
4answers
Set nat to open
These routers have a setting underneath the advanced tab (within advanced setup) called UPNP.....all three of the active tick boxes need a tick in (by default they don't) and this will sort the NAT stuff out.
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
