Acer (91.AB264.001) CD-ROM Drive Logo
Posted on Jun 22, 2010
Hello, I have an ACER Aspire M5630 with Windows Vista operating System. It contains a CD-Rom R/RW which worked fine until yesterday when I went to install a new game and it is no longer reading CDs. When I placed the game in the CD slot it makes a bit of noise as if it is trying to read it but then the autorun will not come on and when I try to manually install the CD it will tell me that drive D is empty. Please note that I have tried to do this with other CDs and the same thing happens. Thanking you in advance for your help!
Anonymous
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Jul 04, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
0
Helped
1843
Points
15
Need upgrade software to cd or you need new cd drive to read new game
cheers
1helpful
My Acer Aspire 5520 doesn't find his Dvd/Cd rom anymore I even tried to delet the upper and lower filters in the regedit resetet my bios and reinstaled Windows Vista still it not working
Hi
maybe you could get the driver from here
www.acer.cam
use scroll down boxes to find your model and operating system
then scroll down and look for the cd/dvd driver if available
good luck
I removed vista and put an original licenced windows xp pro but the dvd does not work and it disappeared from the bios
Vista is proprietary, you need to go out and find the correct driver for that CD-RW/DVD-ROM for that Acer PC.
1helpful
I have acer aspire 4520.I have upgraded to windows xp sp2. The empowering technology does not work.It says " the specified file is not found".I cannot find the empowering technology software...
Acer Aspire 4520 Notebook Technical Specifications:
Operating System Genuine Windows Vista Home Premium Processor AMD Athlon™ 64 X2 Dual-Core Processor TK-57 (512KB L2 cache, 1.9GHz) Chipset NVIDIA nForce 610M Memory 1GB (1GB installed in one of two memory slots) DDR2 667 SDRAM User upgradeable up to 4GB (one 2GB memory card in each slot)* subject to availability of 2GB cards
*If upgrading after initial purchase, one or more of the memory cards provided with the system may have to be replaced with optional larger memory cards in order to achieve the maximum capacity.
Storage 120GB* hard disk drive Integrated variable-speed Super-Multi drive (DVD+R, DVD-R, DVD-RAM):
-Read - 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 6X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 6X DVD-RW, 6X DVD+RW, 5X DVD-RAM
-Write - 24X CD-R, 10X CD-RW, 8X DVD-R, 8X DVD+R, 4X DVD-R DL (double-layer), 4X DVD+R DL (double-layer), 6X DVD-RW, 8X DVD+RW, 5X DVD-RAM
5-in-1 card reader for optional MultiMediaCard™, Secure Digital card, Memory Stick, Memory Stick PRO™ or xD-Picture Card™
Surely to load XP is a DownGrade. As this notebook is dual core, I would run Vista 64 or better still Windows 7 64.
If you wish to persist with an old system, you require SP3 for XP.That may be available from a software store but is no longer supported by Windows.
Try http://www.notebook-driver.com/laptops-information/acer-aspire-4520-notebook-technical-specifications/ for drivers that you will require to have support from Acer.
Hope that clarifies your situation.
Hi, I own an Acer Aspire M5630 Standard desktop
A branded computer uses Original Equpment Manufacturer (OEM) version of Operating System, hence if you change any hardware it will go to the trial version of OS automatically. Hence, you have to use the full system recovery disk to reinstall the OS.
Thanks and regards,
Anil.B.R
2helpful
CD-RW/DVD drive doesn't detect disk on Acer 2930z laptop
may be your combo drive go to demage change it replace another or you use external usb cd rom or DVD must be select usb cd rom/DVD
2answers
Computer problem
Get some other software like Nero. It is mach better than any Windows Software. Especially if you are using VISTA>
Mastersage
2answers
CD-ROM will not read CDs in ACER M5630
Update Acer drivers. I lost 1 USB on my Acer. This resolved the issue. After fixing it change settings to allow automatic updates.
2answers
Dvd cd rom drive disappears
Please access the link given below. This link talks about a problem in the operating system.
http://support.microsoft.com/kb/q270008/
Let me know if your problem does not get resolved with this.
Thanks
1helpful
Acer Aspire 5000 CD Drive Problem
hi!,
1.this is not a problem of your operating system.so don't format again.
2.you must install the drivers for the CD rom.
3.if not fix it is a problem in the circuit board of CD rom,very difficult to fix.
thanks
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
