A USB cable, usually like the charging cable that came with the phone, but you connect the USB end to a computer instead of a 'wall wart' (AC Charger). You may also need a driver for your phone that may need to be installed on your computer.
You shouldn't need the driver to charge the phone, just make sure the USB port is powered. But, you can download the driver here: http://www.nodevice.com/driver/L6i/get39381.html
Some phones cannot charge from a USB connection if their charge is low or the proper drivers are not installed on the computer.
Drivers for your phone be found on this website: http://www.lg.com/us/mobile-phones/mobile-support/mobile-lg-mobile-phone-support.jsp
If installing the drivers does not help, then try charging your phone from a wall charger. Regular sockets provide more power than USB ports, so you may need to use the wall for a while to get the battery up a bit.
Yes cell phones can charge through the computer. This is via a usb data cable. My phone (L7) charges through the computer after being connected to it via a usb cable. You need to connect it as a memory device or a modem. In case of modem u need to install the proper drivers. For each phone this feature may vary.So please check whether the battery meter is moving when it's plugged to the computer.
PS: Dont forget to rate my solution... Thanx n regards
