Siemens SpeedStream 4200 (13A4200001) Bridge Logo
Posted on Jun 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you change from nat type 3 to nat type 2 on this router
I need to change from nat type 3 to nat type 2 because its restricting my online gaming on my playstation 3
Rakesh Warrier
Level 3:
  • Master 708 Answers
  • Posted on Aug 20, 2010
Rakesh Warrier
Master
Level 3:
Answers
708
Questions
0
Helped
209538
Points
1609
To reduce the NAT
1 ) Disable the firewall in the router
2) Enable the Playstation in the DMZ
3) Make sure UPnP is Enabled
I won't to change my nat type
You will need to change the firewall settings of your router. If your Internet service provider is DSL then make sure that modem is in bridge mode. How to change NAT type to open
I cant play online becouse of this a NATtype3 what dose this mean
Nat 3 is the result of being hooked into a router without being properly setup for data transfer. essentially it is restrictive.
There are 3 ways to change your Nat type to type 2 or 1. (Nat type 2 meaning that it is properly setup without restrictions behind a router, and Nat 1 being a direct connection to the Internet).
1.) Hook the PS3mag-glass_10x10.gif directly into the modem will result in a Nat type 1, but of course that means disconnecting everything but the ps3 and that's an unnecessary hassle.
2.) Going into the router settings and Port Forwarding the PS3's necessary ports to the Ps3's ip address.
3.) Probably the simplest (on most routers) and most effective is to go into the router and set the PS3's ip address in the DMZ (DeMilitarized Zone), essentially the router doesnt have any say from what comes and goes to the Ps3, which is good so the connection isn't hampered.
One friend and I can not get into each others lobby
I know 1st hand that there has been an issue with the game network, not the game. Also you have to have a nat type two which means you are linked to router straight, as well as an open nat type in the game. The way to insure you have a nat type 2 is by Going into your router and synching the DNS server and setting up the PS3 with a Static IP as well as putting that IP in your routers DMZ. If either of you or your friend is in a nat type restricted you will not be able to get into eachothers lobby.
How do you open nat type on the ps3 ?
Nat type is actually defined by your isp..(internet service provider) some companies do not actually support gaming and therefore their service is considered "strict" by ps3 standards for multiplayer gaming online. You may have to reconfigure your pc internet security settings on the computer itself...possibly logging into your router/modem. If this is not helpful or u are unsure of how to do this, contact your isp and explain to them you want the nat type changed...basically they will either not be able to at all and then u need a new isp or they can do it in a matter of minutes and ur nat type will change and give u full access to ps3 online within a matter of hours...hope it helps and u get back to gaming!
Not connecting to internet
You will have to open the following ports in your modem /router
Make sure the firewall is disabled in the Modem /Router
Make sure that UPnP is Enabled
Playstation Network Required Ports
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Playstation Online Game Ports
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
You can use http://whatsmyip.org/ports/ to test if the ports are open.
How to change tp link tl-wr641g nat type? I am trying to play online and it says it is restricting my games because nat type is strict?
NAT is Network Address Translation.. It is a setting of the router... you need to login to the router navigate to the NAT page and set it to the required settings save and log out
manual below www.tp-link.com/english/soft/200865140422.pdf
2answers
Cant to get a friend to join online playing Smackdown vs Raw 2008
There is usually two reasons for this.
The first one is the game is just having server problems.
The second one is usually the problem and that has to do with your router settings causing you to have a 'NAT Type 3' connection which can cause connection issues with other players.
Having a closed or limited NAT on your gaming console will cause a variety of issues. Similar to strict, moderate or open on an Xbox 360, the PS3 offers Type 3, Type 2 and Type 1 NAT results. These break down as follows:
Type 1 - Connected directly to the internet (no router/firewall). Should have no issues.Type 2 - Connected through a router properly. Should have no issues.Type 3 - Connected through a router without open ports or DMZ setup for PS3. Everything should function properly, but you may have connection, voice chat or other issues.While most everything will function properly regardless of what your NAT setting is, your best bet is to set up your PS3 so that you can obtain a Type 1 or Type 2 NAT. Since most of us have routers at home for connecting multiple computers or devices to the internet, chances are the best we will get will be Type 2. Thankfully that's fine and everything will work properly.
If you have not adjusted your settings on your PS3 or router, chances are you have a Type 3 NAT and probably never knew it. With a few simple changes you too can have a Type 2 NAT. Order now for just $19.99. But wait, there's more. joker.gif
The first thing you will want to do is check your network connection. Head on over to the Network Settings tab on the XMB. It looks like this:
Once there choose the Internet Connection Test item. It looks like this:
You will receive a warning letting you know that you will be signed out in order to perform the test. Choose okay. If you have not made any setting changes in your PS3 or Router, chances are you will receive the following message:
The warning reads: "When the NAT type is type 3, chat or the communication features of games may be restricted. For more information, refer to the online instruction manual."
If you run the test and have Type 2 or Type 1, stop fooling around and go play some games! If, however, you have Type 3, read on for help on opening up your NAT.
In order to open up your NAT on your PS3 you will need to make an adjustment on your PS3 and on your router. First you will want to set up your PS3 for a static IP address. This means turning off DHCP and assigning your PS3 a single, static IP address. Before you start this process head over to the network tab on the XMB and choose "Internet Connection Status." From here note your current IP address, your subnet mask, your default router and primary and secondary DNS settings. Write these down, you will need them in the following steps.
To do this, visit the Internet Connection Settings tab on the XMB. It looks like this:
From here most of the settings can simply be passed through with default settings. There are two areas, however, that you have to change. The first is choosing a Custom address setting (instead of Easy).
From here, you will want to choose Manual IP Address Setting:
Remember the settings you wrote down from your status page? You will need them here. You will have to enter in the static IP Address you want to assign to your PS3, the Subnet Mask (which is usually 255.255.255.0), the default router (the IP address of your router, most often 192.168.1.1 or 192.168.100.1), and the Primary and Secondary DNS settings. You will have to input all of these numbers. This is made much easier with a DVD Remote or keyboard.
Please NOTE - You will want to set the last number of your IP address high enough that other wireless or wired items on your network will not be assigned the same number through DHCP. While DHCP had chosen .3 as an IP address for my PS3 initially, I bumped it up to .23 because I have less than 23 items in my network. If you do not have DHCP enabled on your router, you do not need to worry about this and can simply choose an IP address that does not conflict with your other devices and which is available through your router.
Once you have all of the settings input, press X to save them. Your settings will change and the PS3 will offer to perform an Internet Connection Test for you. If you let it do the test now chances are you will still get a Type 3 NAT connection. Don't fret little bear, we still have one more step.
In addition to making the necessary changes on your PS3, you will also have to open up some ports on your router. The ports you need to open are:
TCP: 80, 443, 5223
UDP: 5223, 3478, 3479, 3658
I have a Linksys Router and my port forward settings page looks like this:
Depending on what type of router you have, your settings page may look different. In order to obtain an open or Type 2 NAT, you will need to open those ports listed above.
You can see in my screen capture that my PS3 is listed with its static IP address that I set above (.23) and that all of the necessary ports are forwarded to that IP address. The X listed items above (.24) are for my Xbox 360 so you don't have to worry about those.
Once you have forwarded these ports and saved your settings its a good idea to unplug and plug back in your router. This will refresh everything on your network connected to your router. Once done head back to your PS3 and perform an Internet Connection Test. If you did everything correctly you should receive the following page:
Congratulations, your NAT is now setup and working properly!
2answers
My ps3 HAS A dns problem
Whenever you are dealin with a DNS error, it is a problem on your internet service provider's end. Contact them for a solution. Thanks
PS3 NAT type problem using Zyxel P-660R-D1 series DSL Modem
thanks for help , the error was from user that have viruse on his pc , thanks again
Top Siemens Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
