You are correct,now to find out what circuit is blowing the fuse.If the car was in a accident check that area first.Chances are its interrior or running lights.lets start with interrior lights,install new fuse turn on interrior lights on for 1/2 hour.if fuse blows remove interrior lamp lenses and look for one of the hot wires to be shorted out on the body.To check the tail lights turn off the interrior lights and turn on the running lights.If fuse blows start with any damaged areas,check the trunk area for damage to the wire harness,if you have a trailer hitch chcek the trailer harness for damage.theres no easy fix here,hope I have been some help.Thanks for using FixYa......Ray
The Tail lights and Instrument lights are usually on the same circuit so both will go out if the fuse for the circuit blows. Check for a blown fuse for this circuit and replace if out. If fuse continues to fail, check the tail light or side globes for a faulty globe and replace if necessary. Also check for any chafed wires that could be shorting to the body causing the fuse to blow.
