Before you start, please make sure you have a reader that can read and write to 2GB card properly. DO NOT use in built-in reader on laptop and desktop, or old readers made 2 years or longer ago, because these readers can only use up to 1GB card. I recommend using it in external USB 2.0 reader that is made within 1 year ago.
If you do not have such reader, then connect the device (gps/camera/pda/camcorder) to the computer with USB cable and the card inserted and if works you should see new drive letters show up under My Computer.
Otherwise, if used in devices that do not support the 2GB card, the card will be damaged.
Please try the following troubleshooting guide first and see if it can solve the problem. Try one step at a time. If one works, then you can stop trying. You don't need to try all of them.
The following guide will erase all the data on the drive/card. So make sure you backup your data first before you try the steps below:
1. First, remove the card/drive from your computer.
Download the low level format tool below to your computer.
http://hddguru.com/download/software....2.36.1181.exeInstall the program into your computer.
You should see a new icon called "Hard Disk Low Level Format Tool".
a. Insert the card/drive and run the program.
IMPORTANT!!! MAKE SURE YOU SELECT THE CORRECT DISK OR YOUR COMPUTER MAY NOT START LATER!!!
It should shows as BUS: USB. Select the BUS: USB. Also check the size and make sure.
If you don't see BUS: USB, that means the card is unreadable and need to be replaced. In this case, please STOP here and close the program and DO NOT continue below.
b. Then click Continue->Low Level Format->Format this Device.
c. Wait for a few minutes until it finish successfully with a message of asking you to partition and format it. (if you see formatting error, you can stop the formatting and the card needs to be replaced.)
d. Flash Card:
Put the card back into your device and then use the format utility in the device to format the card.
