The message is:
'Check the printer
Press Resume key'
The Alarm light is blinking.
When I open the cover the printhead with the ink tanks does not come in the middle.
So I can not print, scan or change the ink tanks!!!! Only the fax is working. Pressing the Resume key does not help, nether turining off/on the printer or computer.
I would appreciate very much any suggestion. Thank you.
Peter
On the right side of the print cartridge carriage there are two small felt ink pads. When they fill with ink somehow the machine detects it. Mine started with the flashing light and check printer error code and then progressed to a nasty grinding sound everytime I hit resume or tried to reset the counter. I thought all was lost, but kept trying. I found two pads, one square and one rectangular. They aren't very spongy but they are full of ink. They are only about an inch across. I got them out without taking the printer apart and repeatedly soaked them in a little water until the water was clear, then I let them dry and replaced them in the little trays where they came from. I cleaned the plastic fins that were nearby and coated with ink with a Qtip and rubbing alcohol. And I removed the print head and cleaned the muck of ink on the connectors with a Qtip and rubbing alcohol. Much to my suprise, after all of this the damn thing worked fine again when I plugged it back in.
Try re-setting:
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice
5: When the indicator lights steady, press RESUME three(3) times. The indicator should be orange.
6: Press Power to set data
Something similar happened to me: two inks had gone dry, and when I changed them and hit the Resume button, a grinding noise happened and the ink try won't move. Sounds like it stripped a gear but I don't see anything amiss -- any suggestions?
My printer took a long time shutting down when I shut the computer down and the next time I turned it on to print a grinding noise happened and when I open it to try to see what was wrong, the carrier that holds the won't move out of the right parked position. The ink carrier will move freely if I pull it from the parked position and slide it across to the left side and I don't see any broken belts, but the Alarm light continues to be lit and tells me to check the printer and to press the Resume button. When I do it has a racketting sound on the right side of the printer happens again and the cartridge carrier stay where ever it was left-- any suggestions?
Barb
[email protected]
I have the same problem Barb described. I tried the steps suggested by myob247, but if I hold Resume and then hold Power nothing happens.
Same problem accept the fax machine has not worked for months either. Is there a center where the machine can be taken for repair? I am just approximately 15 miles west of Chicago, zip code 60154.
I've tried the power on/off etc. It will sometimes work again when I take the printer head out and clean off the contacts on the back and/or the ink thingies on the bottom with a q-tip. The problem keeps returning.
I don't know whether a new printhead cartridge will help or not. Anybody else tried a new cartridge with success? Failure?
Squid 69 asks for solution to ink tray and printer head will not move when cover is opened printer is a canon multipass f 80 nor will the printer print. All I get is a steady alarm flash and a code that says check printer.
