Question about Seagate FreeAgent Go 640GB External USB 20 Portable Ruby Red 640 GB Hard Drive
No detection at all..
No power,no lights, and a clicking sound
    New Friend:
  • 77 Answers
May be problem with external usb device. check on other systems. If it shows the same problem then contact service provider of your seagate
Posted on Jun 22, 2010
6ya staff
SOURCE:
Panasonic cinemavision 1080i power light blinks red twice, will not turn on
The clicking sound is a safety device that prevents that TV from starting because a fault has been detected.
The fault is also indicated by the two blinks. Two blinks point at a problem with one of the low voltage lines (it should be 15V) from the power supply. The PSU is the part to be tested and eventually replaced. Before calling the technician try to unplug the power cord and leave the TV to rest for about one hour before restarting.
Nov 18, 2013 | Televison & Video
Powers green light on and sound works but can't get screen to come on. is there a certain button to touch to get it on
What Operating system Windows 7 , XP? Right click on desktop, go to personalize, left hand grid find display left click, click on detect, should help. Or, How many buttons are by the power button! One may be marked by a screen symbol> try a RGB cable and hook up to a TV or Monitor!
Oct 21, 2013 | Compaq 2880J Laptop LTE 5380 P133 MHz...
RCA F36648 36' TV will not power on, makes a clicking sound when I try to power on
This set has a number of problem detection circuits and safety shutoffs. The clinking you are heearing is the power relay turning on then off as a problem is detected and hte set shuts down. This is normal expected behavior when the set has a problem. The most common cause of this is a defective horizontal output transistor that has failed. Expect a parts cost in the $30 range for this repair.
Dan
Aug 26, 2010 | RCA F36648 36" TV
Sound card not detected
Try Updating the sound card drivers
Go to device manager (START >RUN > type devmgmt.msc)
Right click and update drivers
Jul 16, 2010 | Intel D946GZIS Motherboard
I have no picture or audio on my TV. The green
It sure sounds like the mainpower supply problem, the power supply may be trying to turn itself off because it detects short circuits.
Nov 01, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Tv wont come on just make a clicking sound when power button is pressed. green power light comes on for second and then goes off.
You have a power supply or high voltage problem that system control is detecting that is keeping the set from coming on and possibly causing more damage. Have a repair shop check it out for you. Thanks for using Fixya.
Oct 27, 2009 | Televison & Video
The lamp indicator turns on
The clicking noise is the protection switch that keep shutting down the unit. This happens when an internal fault had been detected.
Do the following:
Unplug the unit from power for some time.
Remove the bulp and refit it in place.
Restart the unit.
If still in protect mode (clicking , lamp light and no start), then there is a fault.
When the problem is the lamp, the lamp light will come on, but usually protection does not click.
Before buying a new lamp that is expensive, have the projector checked, testing with particular attention the high voltage board that will supply power to the lamp. That may be the fault.
If you have a replacement lamp in storage replace the lamp first.
Jul 20, 2009 | Dell 2200MP Multimedia Projector
No picture or audio.power light blink on once and turns off
The real deal here is the protection circuit has activated. This is caused whenever an excessive amount of current is being drawn from the main power supply. Upon detection of same, it immediately takes over the power management of the set and shuts it down. The clicking sound you hear is the ON relay turning on the set, but immediately the power mangement system shuts it OFF. You should hear two clicks, but they may be so close together that it sounds like one click.
This set is getting rather ancient and I would not recommend you spend much money on it for this reason: It is highly likely that once the set if repaired that another failure would occur. This is because of the law of averages; the first failure is often followed by another failure from anywhere within the set.
May 31, 2009 | Toshiba Televison & Video
My Panasonic Stereo (sa-ak510) will not power on. The red light blinks and makes a clicking sound almost every 30 seconds. Does anyone know what this is?
There is a problem inside that is being detected during the power-up sequence. The clicking is the main power relay that is being tripped when the problme is detected. With no symptoms to guide me other than the clicking, I can't state the exact problem. This could be as simple as a bad cap in the power supply or something more severe. An examination of the boards and some measurements would be necessary to provide you with a reasonable estimate for the repair. I would suggest that you bring this to an authorized Panasonic service center for an estimate first. Armed with their evaluation, I may be able to walk you throught the actual repair.
Dan
Nov 12, 2008 | Audio Players & Recorders
I HAVE NO SOUND ON MY GATEWAY GT5660E. i HAVE TRIED EVERYTHING
Do you have the speakers plugged into the correct plugs in the sound card? Make sure speakers are not plugged into the mike jack. Do you hear any static as you remove and replug the jacks? Do the speakers have a power light?
Open Control Panel ->Sounds and click on Sounds tab. Do any sounds play? Click on the Audio tab and make sure Default device is your sound card. Click on Volume tab and then Advanced. Make sure nothing is muted.
Assuming you have Windows, check the sound card in Control Panel->System, Hardware, Device Manager. Check for correct drivers. If necessary, uninstall sound card and let Windows detect it again and install drivers.
Sep 16, 2008 | Audio Players & Recorders
Seagate FreeAgent Go 640GB External USB 20 Portable  Ruby Red 640 GB Hard Drive Logo
162 people viewed this question
Top Seagate Computers & Internet Experts
Ekse
Alun Cox
Argospete
Argospete
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
